Question about Amana ABB1927DE Bottom Freezer Refrigerator
Light comes on and fan works. But no cold air in fridge or freeze
My husband moved this fridge but it sat around for about two months. We plugged it in and the light and the fan works but no cold air in the fridge or freezer? Please help.
  • soldbyletici Aug 18, 2009
    I am not sure. I can feel a little bit of air coming into the fridge.
  • garry ring
    garry ring May 11, 2010
    is the compressor run?
  • 998 Answers
Can you hear the compressor running
Posted on Aug 18, 2009
SOURCE:
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Refrigerator side too cold
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 28, 2011 | Cars & Trucks
White Westinghouse ( Model# MRT 18FNEWO
Nov 24, 2011 | Refrigerators
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
your defrost timer is bad. this device is dual purpose, it is a small heater/solenoid that calls for the compressor to turn off so the lines can defrost (usually does it once every 48 hours or so). it looks like a round button clipped to the coil lines in the freezer behind the plastic paneling where the cold air comes out. you need to replace that part, which is actually very inexpensive compared to a new fridge. it will unclip from the coil line and the two or three wires will either disconnect or you may have to cut them and splice on the new ones from the new defrost timer. either way it is a job that will take anyone with basic hand tools less than an hour to do.
May 29, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
186 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
