Question about Kyocera Mita FS 3800 Laser Printer
Kyocera 3820DN I just moved my printer.  Now when I turn it on it goes through the self test, but half way it says "check waste toner box" which goes away immediately because it is replaced by "paper Jam"
  • 6 more comments
  • Browes Dec 02, 2007
    I guess I should say that at this point it does nothing else but beep at me. I've checked all the paper jam spots and taken the thing apart and put it back together, but nothing. I've also removed the toner box and shaken it around and reattached it, still nothing.
    Thanks for your help Soulvisitor. I cleaned the neck of the waste toner box, and that solved that problem, however, I am still getting a paper jam message. What are your thoughts.
    Thanks a ton, this is a big help.
    -Bryan
    I pulled the transport, but I do not see any paper in the back there.
    The display says
    Paper Jam
    Printer
    Then when I push the question mark it says
    Open cassette 1 and
    pull out paper
    transfer unit,
    then remove
    the paper jam.
    Also, remove
    the paper jam
    from
    rear cover.
    Close paper
    transfer unit.
    I'm going to now follow the steps from "remove toner. . ."
    I can't figure out how to unplug the developer
    figured it out
    ok, now I'm at the part where I'm supposed to unplug display and click off the sides, but nothing is budging.
    Should I have also told you that This unit has the duplexer and an additional tray?
    Update for when you get back. I followed all your instructions and striped it bare, took out the fuser. I didn't find any paper, so I reassembled everything, and now, with the unit not on top of the duplexer and extra tray, I powered it up and still got a paper jam error.
    thanks again for all this help.
  • Browes Dec 07, 2007
    I cleaned the two things that looked like eyes, and I'm not sure what switch you were referring. It still says there is a paper jam.
  • Kyocera Mita Master
  • 1,113 Answers
If the neck of the waste toner box has toner on it it will think it is full wipe inside of neck stem with tissue.
Turn off and on, does waste message disappear? If it does and you still have jam problem post back and I will help you solve it too
Posted on Dec 02, 2007
  • 8 more comments
  • Soulvisitor
    Soulvisitor Dec 02, 2007
    OK lets find that switch that is held down by paper or just stuck, my bet is there is paper concertinaed in fuser at rear, pull out paper cassette, then on right of machine is a lever that will release transport, this slide out 3/4 of the way but we want it out fully to do so press either sides of slides and pull the rest of way, look in there to the back can you now see the paper?
  • Soulvisitor
    What show on display are we sure it is jam indicator
  • Soulvisitor
    You can remove toner, then unplug developer plug inside where toner goes little plug, release lever that hold dev, pull it out, release transprt, remove waste toner bottle slide out drum to left.
  • Soulvisitor
    Dont touch drum surface, cover it from light when removed
  • Soulvisitor
    Two screw on lid remove top unplug display, sides click off, now you can see all there is to see, there is a switch near fuser exit and entry, also one on transport.. have fun, ussally fuser gets a paper wrapped around it, fuser has two screws at rear hlding it in and 3 plugs running threw sides to left rear and can then be removed
  • Soulvisitor
    Yes to the duplexer being attached, machine needs to be sepaterated from this, two latchs at rear duplex comes off, machine lifts straigt off extra draw, power it up with out these options
  • Soulvisitor
    I should of noticed the DN option sorry my mistake, I'm off to work now will post later, thinking that toner has spilt into a photocell that switch uses to know when open or closed.
  • Soulvisitor
    Soulvisitor Dec 03, 2007
    On the left side of transport you will see two silver bits on switch arms, these line up with "eyes" in where it slides in, clean these photocells there is two of them, there is also a switch middle front machine frame check it works.
  • Soulvisitor
    Soulvisitor Dec 07, 2007
    It has to be one of the spaper path switchs/sensors stuck, or cover switch unable to be activated to enable reset. I think there is one cover on waste toner door and one cover on top cover, the rest are paper path switchs as laid out below, you will win in the end, very few
  • Soulvisitor
    board faults I have seen I these, they are/were tough reliable beasts they had 3 years onsite parts and labour and I find it impossible to remember ever changing any boards due to malfunctions. I've written a heap off from the expense of them needing new drums and devs. yours machine wants fuser exit sensor cleared it must be stuck/dirty/broke/diconnected or cover switch side/top
SOURCE:
The printer continues in Self Test, the printer is stuck at this point as it tries to continue to cycle through the power up.
Try to power on the printer without the toner kit and the waste toner box. If the printer stacks again at self test. Next step.... remove one part at time and check if the printer displays any message. First remove the developer unit and power on the machine (normal message "Missing Developer Unit"). Then pull out the fuser unit and power on the machine (normal message "Close Rear Cover"). And finally, remove the Drum Unit and power on the printer (normal message "Call Service 7410").
If the printer still stacks at Self Test, then that is not a good sign. Try to upgrade the printer' s firmware (system + engine). There is a possibility to go further from Self Test.
If it does not, then you have to replace the main pwb.
Oct 28, 2014 | Kyocera Fs-3920dn Laser Printer
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
Self test says 'check waste toner box'
It looks your waste toner box is full. Waste toner box collects toner drawn during printing. You have to remove waste toner bottle and empty it.
Follow the instructions to clean up toner bottle
http://www.kyoceramita.co.th/news/products/img_promain/20091141129533.pdf
Hope this helps
May 21, 2010 | Kyocera FS-C5030N Led Printer
Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Mar 10, 2010 | Kyocera Mita FS-3830N Laser Printer
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Kyocera FS2000-D error message 7410:0017578
The drum is not pushed fully into the machine.Open the waste toner container door and gently push all units into the printer.Then turn off the printer at the wall.When you power back up the printer should be back to normal.
Jan 28, 2009 | Kyocera FS-2000D Laser Printer
I have a message that says "waste toner box almost full" I cannot find the waste toner box. can you tell me where it is? The copier is a Kyocera KM-8030. thank you Frances
After looking on the net if your printer is under warranty, you should call Kyocera Service Rappresentative or an Authorised Service Centre as Kyocera is not releasing how to empty or clear the waste toner box and if you do you will woid the warranty.
Dec 02, 2008 | Office Equipment & Supplies
Kyocera Printer C5030N
Remove the developer and toner cartridge from the front of your unit. This will allow you to take out your drum where your waste toner box is. Once you have your drum with your waste toner box make sure to detach the waste toner box from the drum. Take a damp linen free cloth and wipe down the inside of the drum unit where your waste toner box goes in. Now take your waste toner box and make sure to secure the waste toner box really well to the drum. This has to be in very tight or else the printer will not think that there is a toner box attached the drum and this error will continue to appear. Important thing is to make sure that the toner box is attached really well to the drum unit.
Oct 18, 2008 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
1,770 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
