GoVideo Go Video DVD Recorder/VCR with YesDVD
Problem for GoVideo Go Video DVD Recorder/VCR with YesDVD(tm)
I have a GoVideo Model DV2150. I'll turn to
By Tami654 on Aug 18, 2009
I have a GoVideo Model DV2150. I'll turn to channel 3 to set-up a timed recording. Later, when the vcr turns on (at the appropriate time) it scrambles the station that I'm currently watching and when I turn to channel 3, it becomes the channel that I had set to record. I did get a response from a "Guru" who was kind enough to explain how to mess with the cables in the back of the machine, but I'm not that tech savvy and had hoped to find an easier solution. Also, when I set the clock, I have to do it on "manual" and the time tends to change a little (a few minutes fast, usually)....I can't use the "auto" clock setting because it'll randomly change the time, date and year.
Comments:
Aug 18, 2009
- Thanks for your help. Well, if that's the case, can you give me some direction on how to change the cables?
Aug 20, 2009
- Thanks so much for your quick response! Yes, I'd like to watch one channel while recording on another. It's worked fine since I originally hooked it up, so I don't understand what could have changed, since I haven't touched any of the cables in the back. It would be great if you could direct me as to how to fix the problem without messing with the cables...but, if that's not possible, I'm hoping that you can give me an idiot-proof version of how to change the cables. Thanks again!!
Aug 20, 2009
- Hi Tim: Yes, I've always turned to channel 3 to set-up my timed recordings. And, no, nothing has changed in the set-up or programming. I'm really baffled that all of a sudden it won't work.
Aug 20, 2009
- I've had it for a few years..it was a gift (I never would have bought it on my own). It's definitely not the best machine I've ever had...actually, no other VCR has ever given me any trouble. But, I have an old t.v. and the newer VCR/DVD players don't work with the old t.v., so I guess I have to invest in a new t.v. and get a new VCR/DVD machine. But, I was wondering if you might be able to give me some advice on messing with the cables...just to see if it helps.
Solution #1
posted on Aug 18, 2009
Not Rated)
micromatikal
Rank: Wiz
Rating: 84%, 249 votes
Wellt here is no easy way to fix the issue without messing with the cables on this one. When it changes the input to channel 3 it is drawing away all of the signal. You need to use a different input all together for whatever else you are wanting to do.
Comments:
Aug 18, 2009
- The more I read your question the more I wonder if it is possible to do what you are hoping to achieve. So you want to watch live TV and record live TV at the same time correct? Using just one coax input?
Aug 20, 2009
- So have you always turned to channel 3 to set up your recordings? Has anything at all changed in the setup / way you use it / programming that could have caused this?
Tim
Aug 20, 2009
- It sounds like the unit may actually be malfunctioning, if nothing in the setup has changed there is not a whole lot else that can explain what is happening. How old is this unit? It may still be under warranty..
Thanks, let me know
Tim
Aug 20, 2009
- Well you can try locating the red yellow and white connectors on the back of the GoVideo box, and the the same connectors on the TV. You can connect those two together. Then you should be able to change to "input 1" or "video" mode on your TV to see the picture.
Try that out =)
Thanks
Tim
Popular Solutions for GoVideo Go Video DVD
Questions and Unsolved Problems for GoVideo Go Video DVD
Do you recommend GoVideo Go Video DVD Recorder/VCR with YesDVD(tm)?
Answer
Answer
DVR4000 - I have an outside source video line in and SVideo out. No outside video plays on Line 1 or... (More)
Answer
How do I finalize my DVD. Can I e-insert it and finalize so that I can play it in other DVD machines... (More)
Answer
I've had this thing forever, always used HP Plus R DVD's. Bought some gold DVD's for archiving,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in New York, NY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
