Edgestar Portable AC/Heater
We misplaced our owners manual to this thing for the heat part of it. We have it running and there is cold air running out the back of it. Do we need to have the hose runningoutside hooked up in the winter? I know in the summer it has to vent out for ac. Any suggestions?
  • 63 Answers
Yes, you need it to be hooked up in the winter also. If you don't have it hooked up then you are heating , and cooling the room at the same time.
Posted on Jan 28, 2008
SOURCE:
Do I need to keep the hose connected to the window in winter time while I use the heater.
The hose is only needed to pump out hot air while using the AC features and not needed at all for heater functions.
Oct 15, 2013 | EdgeStar Portable Air Conditioner Heater
How far from floor should exhaust hose hole be made edgestar 12000
makes no difference, as long as the ducting is not kinked.
keep in mind heat rises
so obviously if you could dump the heat elsewhere, away from the area you are cooling, then it would not creep back up through the floor. If your flooring is well insulated it will not matter.
Oct 10, 2009 | EdgeStar Portable Air Conditioner Heater
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Water leaking
You have to open it and clean out the water passages.
Jul 23, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
Heating
http://www.edgestar.com/ownmanuals.htm
Here is the URL for the Edgestar owner manuals. You can select your unit on the page. You'll need Adobe Reader to view the manual.
Nov 28, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
