I'm assuming you have had a competent Air Conditioning contractor look your unit over.if you trust your A/C contractor, why don't you work with them towards an answer? I would get an air flow and sizing analysis, a full equipment service/performance check, and see if there is something simple causing this dilemma. Possibly low refrigerant charge,or you have a filter or coil restriction on the indoor unit. I've seen mold plug a coil solidly before. And due to new federal regulations on air conditioning efficiency and the phase-out of R-22, I would recommend that any replacement equipment be done in full, not part and parcel. The newer two stage energy star rated cooling and/or heat pump offerings are a fantastic solution for premium indoor comfort, and the government is offering powerful incentives right now if you're in the market.
Testimonial: "Thank you for your advice and your time. I am going to do a complete inspection and cleaning of the air handler inside and go from there. "
You have had it sized I hope for the unit...A/c tech should have done that...if not you can do it your self..
