Question about Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool gs475lems range oven problems
When we turn oven on, it preheats ok, but when the preheat timer counts out and the display shows the operating temp. about a minute later the oven beeps and displays the following code E2 -F3-
  • Anonymous Oct 22, 2008
    when you turn the oven on to bake and after the preheat timer goes off the oven shuts off beeps and flashes a code, also the oven light constantly turns on by itself and is hard to make it stay off
  • Anonymous Mar 08, 2009
    my oven does not work at all. the top of the gas range works but the oven itself does not. it clicks but there is no flame.....
    New Friend:
My oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Posted on Dec 21, 2013
    Sergeant:
  • 415 Answers
It means bake range over temperature.
have a technician check out the oven temp sensor. you may have a short in wiring or it may need to be replaced.
if problem still persists, replace the clock.
Posted on Sep 13, 2008
SOURCE:
75585891 gas range will not preheat oven. Everything seems to work. but oven will not show that it is preheated.
If I understand it is working just no lighting the preheat lamp? May just be a burned out lamp. Connect a jumper from any of the other indicators to the preheat. If it lights there is a problem in the oven control/thermostat. If it does not light when the other lamp you connected to it lights, it is the lamp.
Eric
Jun 28, 2009 | Kenmore Kitchen Ranges
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Jan 08, 2018 | Whirlpool Kitchen Ranges
Wirlpool gs475lems Oven will fail to light and keep temp.
I HAVE A 2 MONTH OLD GAS RANGE AND IT APPEARS ED-F3 AND THE OVEN DOOR IS LOCKED HOW DO I GET IT TO UNLOCK
Feb 15, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
Oven preheats then cuts off 70 % of the time
have you checked that your timer is set correctly
Jun 14, 2008 | Ovens
Unable to preheat
You need to replace the temp. sensor. It's not reading correctly. These occasionally go when you use the self clean as the range gets up as high as 900 degrees. Replace it and it will solve the problem
Nov 29, 2007 | Whirlpool SF367 Gas Kitchen Range
Whirlpool GS475LEKS Gas Kitchen Range Logo
1,172 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
