Can you tell me what tool is required to drive the screw out of the casing. Looks like it is a special tool. Please advise if it is available in the market. Thanks a lot.
-   Screws are basic t-15 or t-20 but they have a small metal "tip" inthe middle that prevents the screw driver from backing it out. So, do they make a tool for these (besides the ones at the factory which we probably do no have access to)? -   baileybs1
You don't need to remove those triangular screws. Just remove the standard phillips head screws. Slide the plastic "foot" off, & you should gain all the access you need. If you should determine to go after those triangular screws, anyway, there are two ways. 1. with a dremel cutting disk, cut a slot in the head of the screw, and remove with a regular screwdriver. 2. Sacrifice a cheap screwdriver by putting it to a grinding wheel, and forming it into a triangle.
I have a Honeywell HZ514 heater. When I turn it on, it will not heat up. Could it be the thermostat?...
(More)
I have a Honeywell HZ514 heater. When I turn it on, it will not heat up. Could it be the thermostat? How do you get the back off? There are different screws on the back. They look like phillips head, but my screwdrivers don't work
I have a honeywell programmable therm. , model no. RTH7400D1008. It is completely programmed but it...
(More)
I have a honeywell programmable therm. , model no. RTH7400D1008. It is completely programmed but it is a day behind
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
