Question about HP Officejet 4355 All-In-One InkJet Printer
Out of 4 colours i am getting only 3 colours output
After refilling i am not getting yellow colour at all on printed material
After putting paper for copy it shows paper jam
Posted on Mar 29, 2008
SOURCE:
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
Won't Print Yellow Ink
your yellow colour is used mostly please refil your colour cartridge or change your colour cartridge.
Jul 30, 2009 | Epson Stylus C44UX InkJet Printer
I have refilled my Ink Colour catridge, and now when I print documents the yellow colour can not be printed / come out..please help me
The yellow print head is clogged or you are out of yellow ink. You can try to get it flowing with a warm wet paper towel by rubbing and and pressing it into the towel.
Jun 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Hi, I have a Canon Pixma mp460 printer. I had a problem whereby al my attempted colour printouts came out green-blue. I decided to get my cartridges refillled hoping that the problem would be solved....
You can refill them but you have to do it striaght away otherwise it dries up and is knackered. Do it yourself remove the label on top and drill 3 holes for the colour (you can get a guide for it with refill kits) sending them somewhere will cause them to dry up, as they need doing as soon as you loose a colour.
For now get a new cart and fill that when it runs out.
Jan 20, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Lexmark X1100 Series won't print in colour after cartridge refill
I have refilled my cartride many times. Sometimes the colour has not worked so I found that if I put the lower end in hot water and made sure all 3 colours came out in the water the printing then worked. It simply was clogged after refilling.
Dec 27, 2008 | Office Equipment & Supplies
The upper 2/3 of the word is either red or yellow
let the cartridge be new but the colours are got mixed with each other so this problem as the canon cartridge has the sponge in the cartridges that sponge material has soaked the colours from each other and this has happened.to solve this problem two things needs to be done 1)the head needs cleaning as the colour will be filled in it now.
2)the cartridges needs to be replaced.
Dec 15, 2008 | Canon BubbleJet i560 InkJet Printer
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My printer will only print in blues pinks and purple and black and white
ur printer prints in blues pinks n purple: its very simple :there r three prime colours in ur colour cartridge that forms all the other colour variation they are cyan, magenta n yellow. ur yellow colour in ur cartridge is either dried or empty thats the reason its not printing the colour variations which requires yellow. the solution is to either get ur colour cartridge refilled or replace ur colour cartridge. rate this solution as fixya n encourage us to help u solve ur problems in future too.thanks 4 using fixya.
Jun 12, 2008 | Office Equipment & Supplies
HP Officejet 4355 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
