Question about Onkyo TX-SR500 Receiver
Help w/ Bose Lifestyle 12 system
The sound on the system works - am able to play music from the radio and CD player. However, cannot get sound in from my television. The input jack works because I tested it by playing a CD in my DVD player. I also tried hooking up directly to my cable box and that doesn't work either. ANy thoughts?
  • SERGIE HERNANDEZ
    SERGIE HERNANDEZ Mar 17, 2008
    my lifestyle receiver lights are out, cannot see the radio stations,cd,video,aux. Also the center speaker is not working. thanks
We had the same problem. Our TV has an internal mute on its menu. Once we muted it from there we could use the Bose system.
Posted on Sep 20, 2008
Does your TV have a pre-out double RCA panel connector? Some TV´s have to be told which output to use for speakers. (Additional or within..) Check settings on the TV, and possible other RCA connectors, check the in/out symbols (should say output), and try again.. If you are sure the RCA´s on the system works, the problem would have to be the TV/settings or maybe the cable..
M :)
Posted on Dec 07, 2007
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
I have a Bose Lifestyle 35 Series II and want to know whether it's compatible with a DVD+RW. I'll burn it in a Toshiba recorder, finalize it and then play it on the Bose. Will it play?
Hi This what Bose say about formats
"The Lifestyle® 35 system plays DVD-video in interlaced format, as well as music on CD, CD-R (recordable) and CD-RW (re-writable). The system also plays MP3 files on CD and AM/FM radio. "
So by the sound of this i suspec that you may struggle with DVD/RW. but my best advice is try it.
Nov 10, 2009 | Bose Lifestyle 35 Series II System
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Jul 01, 2008 | Bose Acoustimass 15 System
CD player
Not much of a answer but there are plugs that you can hitch a exterior cd player to it
and well you still will have that great Bose sound...yeah!
Feb 22, 2008 | Bose Lifestyle 20 Shelf System
Bose Lifestyle 12 Porblems
sorry mate, looks like cd 5 is damaged goods...... wheter you damaged it or not, can't say....
however, make sure. when you try to play cd, that the cd button, nearest display was pressed as just putting in a cd isn't automatically taking control of the cd function like in other cd players. ( that is to say you have to diliberately select CD mode to play cd's)
if you fancy a load of electronic messing and visits to radio shack i am sure you can repair it if broken,
or a second hand cd unit could be obtained elsewhere on line.
Jan 02, 2008 | Bose Lifestyle 12 System
No sound from my TV!! HELP!!
assume its a bose system 12 (non digital or digital ?)
if you clarify the model of both tv and bose system i will tell you precisely how to connect tv to bose system,
but i must assume first that your cable box is connected to your tv via a scart cable , you must remove sound function from the cable and plug directly into cd5 unit on either auxillary or video input , then turn cd5 unit to that channel to play sound and use bose reomte to control volume (ok)
i would doubt thatthe TV has a audio output, many dont.... also it may be necessary to buy a scart to RCA cable at your local electronics shop or supermarket to completet he task at hand.
if however you are digital.....
make sure you are connectiong bose digital input to a digital (dolby 5.1 compatible) sound source.
sorry if you think i have over simplified the problem !
respect
Dec 02, 2007 | Bose Lifestyle 12 System
Lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Jun 14, 2006 | Bose Lifestyle 12 System
Onkyo TX-SR500 Receiver Logo
106 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
