Question about Acer Aspire 5315 Notebook
My acer aspire 5315 doesnt charge properly.
I have an acer aspire 5315 laptop, and it plays up alot, but the most annoying recent problem is that when i plug my charger into the socket at the back of my laptop, alot of the time it doesnt charge. The battery light on the laptop lights up when the charger is inserted into the socket and is charging, but alot of the time when i insert the charger, it flickers on or off.
Im starting too wonder if its the socket on my laptop itself, or the charger thats faulty? The charger does wobble about in the socket abit, if i position it right it will charge, but it can slip and move which causes it too stop charging, so when im usinng the laptop it will turn off alot because it has ran out of charge even thought the charger is plugged in, and i havent noticed that it has slipped in the socket.
im really confused. and this is becoming a large problem.
  • bethanymorto Aug 18, 2009
    thankyou :) i was reallly stuck until today, i cant afford too take it too a repair shop at the moment, as my local one is very expensive, but my father is rather good with computers, not so much laptops though, but he claims if its come loose, a bit of solder too fix the pin back too its original place could be the answer too this problem, what do you think?
  • Acer Master
  • 4,806 Answers
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Posted on Aug 18, 2009
  • Lee Hodgson
    Lee Hodgson Aug 18, 2009
    I'm sorry solder won't hold it as it's the pin in the middle which has come loose.
    You can order a replacement adapter on eBay, they cost no more than 5 dollars (2-3 pounds), you can order the part by your laptop model number.
    As soon as it comes all your father has to do is de-solder the old adapter and solder in the new one.
    Your laptop will then good as new.
SOURCE:
Acer Aspire 5315 charging circut fuse
So you have removed the battery from this laptop for at least 30secs - 1minute? Not really sure about a laptop fuse? Test your DC jack for continuity - with a volt meter - outside prong and inside stem. Those will be the first few steps to finding your issue.
Troubleshooting Laptop Adapter and DC Jack
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Jun 02, 2014 | Acer Aspire 5315 Notebook
How to get my acer aspire 5315 to use google play apps
Hi.
You can't use Google Play apps on a laptop as the apps are designed for the Android operating system. Laptops only support Windows or Linux operating systems. However, you can download an app to the computer and transfer them to an Android device.
Regards.
Jan 02, 2013 | Acer Aspire 5315 Notebook
How to play a DVD-RW on Aspire with a DVD/CD-RW
just put the dvd in and open it with windows media center or any other dvd/media software
Jan 17, 2010 | Acer Aspire 5315 Notebook
Ok i have had my acer aspire 5315-2326 for a year
try downloading the compatible acer aspire webcam software for your laptop. My laptop is also acer. It is aspire 4730z and it works perfectly fine. I think the software you are using is not compatible with your laptop.
Also most aspire models have lesser durability webcams. It gets really annoying when webcams of aspire won't work. I completely understand your situation.
Just follow my instruction and it will work perfectly fine.
Aug 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
Hi i have an acer aspire 5315 it wont charge properly as charger port in back of laptop has been pushed in slightly how can i fix this
open the laptop i mean the board..then fix if you can if could not do that bring your laptop to the nerest shoorom for fixing that.
Jun 05, 2009 | Acer Aspire 5100-3357 Notebook
Need a cord to charge laptop
dear,
check it . hope it will help alot.
http://global.acer.com/support/service.htm
or
http://forum.notebookreview.com/showthread.php?t=106595
regards,
dont forget to rate it
Jan 06, 2009 | Acer Aspire 5315 Notebook
Hangs up on the standby,hibernate,and shutdown screens
In my case with an Aspire 4710 it was the old or incorrect chipset drivers from the Acer site.
After downloading the proper new drivers from Intel all is fine.
http://www.intel.com/support/chipsets/sb/CS-022034.htm
Mar 05, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook Logo
890 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
