Question about Samsung HLN617W 61" Rear Projection HDTV
Squealing Sound when I Power on my TV
Do any of you experts no why my DLP is making a high pitch noise like this? This TV is on it's second bulb and has been working great for me only that recently it been having this issue. I think its the fan that cools the bulb.
1. Is it a part I can order and repair myself?
Thanks and any suggestions would help.
  • Anonymous Dec 22, 2007
    I have almost the same problem, but the noise was noticeable until it warmed up, then quieted. The only other noticeable thing was that the picture was dim at power up and then got brighter as it warmed up. Upon noticing that the noise was getting louder the lamp blew out and now there is no picture or noise. Does the fan not turn on when the lamp goes out? I haven't been able to locate a lamp as yet, there are no stores that carry it so I'm just waiting to find a location to purchase.
    Signed: No TV for Christmas 2007.
  • 179 Answers
The color wheel is probably bad..with the age of the set you should have a tech replace it because if you get dust in the optics it is very hard to remove and will make the picture have dots and spots all in it
Posted on Dec 02, 2007
SOURCE:
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
50 " DLP makes a high pitch squilling sound and shuts off several times
Check and replace its color wheel. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 10, 2014 | Samsung DLP HL-P5663W 56" TV
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
I just replaced the lamp on my samsung HL-P5063W (DLP TV)...now the TV will not turn on (no picture...but I do get sound)...when I plug it in, it automatically starts to power on...then it starts making...
Sounds like a bad color wheel. Generally when the color wheel goes bad, when you try and turn the TV on the lamp will ignite for a couple seconds and then turn off. It also makes a rather high pitch squealing noise.
www.Partstore.com should carry a replacement color wheel for your TV
Sep 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
