Question about Olympus XZ90 Microcassette Tape (XZ-90, XZ 90)
Olympus XD60 Microcassette
Tape tore from wheel - not attached. Is this fixable??? Very important document contained on tape so we need to get it repaired. Help!
    Scholar:
  • 43 Answers
If the tape has ripped from the wheel itself then you can glue it back to the wheel with a good strong glue (I'd recommend araldite), or if the tape has ripped you can use sellotape to fasten the two sections back together.
I believe this cassette is moulded plastic so what you will need to do is carefully break it apart along the central seam to access and repair the tape itself, then use your strong glue to glue it back up after the repair is done. You have to be really careful dong this so as to not get glue inside the tape itself and gum up the mechanism.
Finally make sure you leave it to set properly before you try and play it (refer to the glue packet), for araldite I think its 24 hours. Also if you use glueto stick the tape back to the wheel make sure that is set before you reassemble the cassette or your wheel will get jammed.
Posted on Dec 02, 2007
The correction tape is not working
If the correction tape is lifting properly try a resh ribbon and L/O they do get old.
DickyO
Apr 09, 2014 | IBM Wheelwriter 30 Typewriter
Will not rewind or fast forward microcassette tape. Makes a noise like rewinding or FF but then starts beeping. Not a tape issue, tried other tapes.
Nothing like going back in time. Think what you have here is a belt issue. As in the belt has stretched over time and is no longer tight enough to hold when you engage the motor on ff or rew. Repair shop might be able to help or else you might want to consider a new machine which is all digital recording. ie no moving parts inside.
Nov 04, 2013 | Olympus Pearlcorder T1010 Transcriber
The voice recording fades in some parts
- Possibly the recording head may need cleaning and demagnetizing.
- The tape itself could be damaged or even folded.
- It may be also because one or both backup pads are missing on the microcassette.
There should two pads behind the tape as shown below.
May 31, 2011 | Sony M475 Handheld Cassette Voice Recorder
I need the instructions manual for olympus pearlcorder j300 microcassette
put in 2 AAA batts and insert a tape, then push record to record, and expirament!
VCVA
set it to VCVA on the left side and push record, will only record when detects noise
Oct 24, 2009 | Olympus Pearlcorder J300 Handheld Cassette...
Microcassette recorder is eating my tapes
Try cleaning the heads with a head cleaner and making sure none of the parts have become loose due to extensive use.
Jan 07, 2009 | Sanyo Audio Players & Recorders
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Electronics - Others Logo
232 people viewed this question
Top Olympus Electronics - Others Experts
Marvin
Marvin
Are you an Olympus Electronics - Other Expert? Answer questions, earn points and help others
