hi,
I am having problems gettin an OCE 3121 printer to work with NDPS.
I have setup various other NDPS printers including some other OCE models and
these work fine.
I am using the Novell gateway and the printer is setup as an IP/LPR printer.
In NDPS Manager the printer shows up as idle and appears to be ok, but as
soon as i send a print job to it, the printer status changes to printing and
then straight away shows as 'Error printing' and shows as 'I/O Error'. The
job is listed and i can delete the job from the manager, then if i shut down
and startup the printer (in NDPS manager) it shows as idle again, unil i
send another job.
Has anyone else had a similar problem, or can suggest something for me to
try as it is driving me mad.
Thanks
Janine
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 25, 2007
error for 7.1
Rating: 0%, 0 votes
OCE 3121 printer.
When setting up the printer using the Novell Gateway and IP/LPR connection I
had to change the printer name from the default of 'PASSTHROUGH' to be
'print'.
This simple change fixed it and they now work perfectly.
Hope this helps with your OCE 3140.
Janine
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
We have the same problem with an Oc?? 3140 and the Novell gateway, with
our 65 HP printers there are no problems.
Toon
