Question about Pioneer CDX-P1280 12-Disc CD Changer
CDX-P1280 multi disc unit locked up
I have a unit that has locked up with disc 4 still in the machine...I am not sure how to get the disc back into the 12 disc cartridge. It is locked up. No power getting to the unit, the unit is not showing up with my reciever. I have a Pioneer DEH-P560MP Premier reciver in the dash and the CDX-P1280 unit in the trunk. I have a dodge intrepid 2000. Any thought on if this could be a fuse issue? Who do you go to for repair for these units or are they disposable? Toss it and get a new one? How do I get the CD's out?
  • 78 Answers
THIS UNIT HAS A SEPERATE TWO WIRE PLUG AT THE BACK OF THE CHANGER WHICH POWERS IT, MAKE SURE THERE IS 12VOLTS GETTING TO IT
Posted on Dec 06, 2007
SOURCE:
How do I remove cds from a pioneer 12 disc changer with no power?
You can remove the CD's with no power just use a pin to open the CD drive. you can see the a small reset hole to open the drive. You just insert the pin to the small hole and push now you can pull the drive slowly to open and remove the CD's.
Mar 19, 2010 | Pioneer CDX-P1280 12-Disc CD Changer
How do I instert a CD into my pioneer deh-p6200 car radio?
Slide the door open (1/2 gray 1/2 silver door) on the disc changer, inside is a push button that ejects the 6 disc cartridge. Load and unload cd's into it.
Oct 05, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
I get a error ll message on my Pioneer CDX-P1280 cd player what does that mean and how can i fix it?
it maybe a programing problem in one of your programable chips that controle that erea if its new send it back and get a new cd player and also contact pioneer service center thier realy great and will help you
Jul 09, 2009 | Pioneer CDXP1280 Multi-Disc CD Player...
Pioneer cdx p1280 cd changer,the cd magazine will not eject.the power is all ok,tried the rest button bt still no go.
cd changer reqs a verygood 12v source,check for a good earth&check how many volts are going to changer with a good quality voltmeter,check at changer,not head unit
Jul 03, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Cd magazine will not eject,power is connected any soloution
Try holding eject as you turn the unit on? should clear any cd's in the transport then try ejecting. Good luck
Jul 03, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Jan 04, 2008 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer CDX-P1280 12-Disc CD Changer not working,
sure............give the details of your problem and we will solve it
Nov 01, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer cdx P1280 error11
pnoman: Your code means an electrical/mechanical failure. Follow this: 1. If the cartridge is stucked try to force it out slowly with a fine screwdriver. 2. Once is out or if already out without forcing it, remove all remaining CD's. 3. Insert a laser lens CD cleaner. 4. Clean it at least 3 times. 5. The unit must be disconnected from the 12V signal to be reset it at least 5 minutes, then reconnect. 6. If problem re-appears repeat procedure once more. If problems still, your laser lens is damaged and need replacement. Probably from $40.00 to $55.00. SithPitt
Jul 04, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer CDX-P1280 12-Disc CD Changer Logo
381 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
