Question about Canon Optura Xi Mini DV Digital Camcorder
Auto power off
I have linked my camera and my mac with a firewire cable. I use IMovie 06 to capture in time lapse mode, but the camera would shut down after 5 min.  So I looked online and was told to remove the tape, and that would bypass this. So I did, but after 5 min, it enters demo mode and goes thru all the sample filters etc. that the camera has.  I also tried using the wall power supply, and it still goes to sleep with tape in and demo with tape out. Any Suggestions? Roger
  • lightsgo Dec 02, 2007
    I figured out that you have to leave the tape out of the camera to keep it from auto power off. You go into Menu > Display Settings > Demo Mode and set it to off.
    That fixed the problem.
  • 140 Answers
Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery.
When using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder.
Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Also check the options in both sides (camera and MAC) while connecting through cable, maybe some options there is wrong configured.
i searched many sites, all people complain about turning off, but others say that it's not turning off while playing through cable USB or firewire.
Posted on Dec 02, 2007
  • Canon Master
  • 1,113 Answers
Link to user manual
No you can't turn off this feature
Nathan Petersen June 17th, 2005, 04:03 PM Is there away to turn the auto power off off. I dont think there is, just thought I'd ask, thanks. Don Palomaki June 17th, 2005, 08:47 PM Not on the original XL1. It will drop into STANDBY from PAUSE if there is a tape in the transport after around 5 minutes. If there is NOT a tape in the camcorder it will not not drop into STANDBY but will remain operating as a camera. Xander Christ June 17th, 2005, 09:25 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true. Don Palomaki June 18th, 2005, 07:33 AM True - in that when using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder. Nathan Petersen June 18th, 2005, 04:52 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true.
No it still does it with the AC adapter, Im not even using the battery. It makes no sense to have the auto power off when shooting indoors while using the AC adapter, its just stupid. Don Palomaki June 19th, 2005, 05:59 AM Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Pro users complained, so the XL1s had an option to disable this feature so that only the tape transport (VCR portion) is turned off after 5 minutes, the camera head continues to run. link to above thread
  • Soulvisitor
    Soulvisitor Dec 02, 2007
    Great news I'm sure many will find this thread usefull
SOURCE:
Need the USB Driver for Mac. for the Panasonic gs65.
According to the user manual under OS X the driver will already be installed on your mac. Have you attempted to plug in the Camcorder to the mac. You could also try to use a firewire cable to the firewire port on the camcorder or the mac.
I don't have the panasonic camcorder but a sony and what I do is attach it to the mac with a firewire cable then open imovie then under the file menu go to import from camera and it picks up the camera and then use the camera controls in imovie to control rewind and play and capture the movie. Of course, the import is done in realtime. A tutorial for this can be found at http://desktopvideo.about.com/od/desktopediting/ss/imoviestart_3.htm Hope this helps in some way.
Mar 29, 2011 | Computers & Internet
Panasonic nv gs30 can support mac
Connect the camera to a Mac and open iMovie then capture.
You will need a 4 to 6 pin firewire cable.
Note: Some Macs have a nine pin socket and some base models have NO firewire socket.
Mar 06, 2011 | Panasonic NV-GS30 Mini DV Digital...
We would like to import footage from the Panasonic NV-GS 400 digital video camera onto a MAC - is this possible
Yes, you can transfer the videos from the Camcorder to the Mac Computer.
Connect the Camcorder to the Mac Computer using i.LINK/Firewire or USB cable.
I suggest that you use the i.LINK/Firewire cable to connect it to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer.
After connecting the Camcorder to the Mac Computer, open the iMovie Application to capture the Videos from the Camcorder and follow the on-screen instruction to complete the transfer of the videos.
Good Luck!!!!!!!!!!!!!
Nov 18, 2009 | Panasonic Cameras
IMovie and Canon ZR500 no image
I have a slightly different but related model of Canon camera. I have found that if you erroneously power it on in "camera" mode instead of "playback" mode, you get the symptoms you describe: you can control the camera with iMovie, but you can't get any video out of it. Make sure you have the power switch in "playback" position -- it's an easy mistake to make.
Nov 12, 2009 | Apple Power Mac G5 Desktop
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Unable to download video from JV dvl520 to my mac
Is it connected with a firewire cable? Have you been able to import the video before to your Mac?
If it it says it is in USB Mode - then change the camera menu setting to DV.
Power off the camera, shut down iMovie - power on the camera then launch iMovie check again. (Assuming your using iMovie).
Dec 20, 2008 | JVC Cybercam GR-DVL520 Mini DV Digital...
Capture software for apple mac
Try the makers website under support, most are eccepted by the mac without but usually via firewire
Sep 09, 2008 | Panasonic VDR-D300 DVD Camcorder
Panasonic SDR-H40P/PC
This camera will only work with the latest version(s) of iMovie (08 and 09). I'm not sure, but you may need an Intel-based Mac also/too. Any previous version (for example, iMovie HD, aka version 6) will NOT work with this camera out of the box.
There is a workaround. You will need the MPEG2 Playback Component for Quicktime from Apple ($20) and a free program called MPEG Streamclip. I also use OS 10.5 (Leopard), and this has worked for me. Once the component is installed, drag the .MOD files from the camera (it will appear as a disk on the desktop when you plug it in and turn it to "PC Connect" mode) one at a time into MPEG Streamclip. Then export them to the DV file format, which is what iMovie uses. Depending on the length of the clips, this can take a fairly long time. Good luck.
May 28, 2008 | Video Cameras
Camcorder to Mac Sony dcr-hc32
Maybe this FAQ will help ya? Problem: Camcorder will not connect to iMovie - No camera attached Possible Solutions: * Are you using a 4 to 6 pin firewire cable? That is the ONLY thing you can use. No USB cables or anything else * Are you using a compatible camera? Still cameras that take movies are NOT a DV camera * How new is the cable? If it is pretty old or you have kinked, it you may need another one * Is the camera in DV mode? It should be. (Usually in the menu options somewhere) * Have read ALL of Apples help topics on this If your good with all the above: 1. Close iMovie 2. Delete all iMovie plist files for iMovie located in Home/Library/Preferences 3. Plug the camera in to the wall (electricity) 4. Make sure you have a good firewire cable and plug it in to the Mac from the camera 5. Turn off your camera 6. Reset your pram 7. When the Mac is booting, power on the camera 8. Start iMovie Sony camcorder special fixs: 1. Turn your camcorder to Play mode. 2. Press menu button (or relevant touch-screen button) 3. Click the 'ETC' item and then to CONTROL. 4. Select i-link (and not IR). or 1. Turn your camcorder to Play mode. 2. Press the Menu button (or relevant touch-screen button) 3. Scroll down the Menu to the 'ETC' option, if there is one 4. Click the 'ETC' item and choose 'VIDEO EDIT' if it's there 5. Click 'VIDEO EDIT' and 'MARK 1 IN' may appear 6. Click on 'MARK 1 IN' and then exit from the Menu options, by pressing the Menu button again Your Sony cam should now work OK with iMovie. * Reason? The camera and Mac can't decide which device is giving the FireWire instructions, and which is supposed to be receiving and acting on them. Using this sequence (above) lets the camera receive instructions from iMovie.
Sep 14, 2005 | Sony Handycam DCR-HC32 Mini DV Digital...
Canon Optura Xi Mini DV Digital Camcorder Logo
577 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
