Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Cannot acquire network address from access point
I have a new laptop with a wireless adapter but my wireless connection is stuck on 'acquiring network address' . How do I fix this?
    Novelist:
  • 173 Answers
Then it seems thatb the wireless security key for your network is incorrect, make sure if you are entering the key correctly..
or else..
check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Posted on Dec 06, 2007
  • emohboub
    emohboub Apr 24, 2012
    there is an expected solution or someone missed something. there should be at least one static ip address within the network that is the internet gate. please check if you got a fixed static IP address or not
  • emohboub
    there is an expected solution or someone missed something. there should be at least one static ip address within the network that is the internet gate. please check if you got a fixed static IP address or not. if it works keep us informed
The wap54G is having issues. Computers trying to connect to it keep acquiring ip address and never connecting. Any advice on what might be wrong?
Hi williamrayes,
If you have a message that acquiring ip address you can Power Cycle the router for 2 minutes then try to connect again or you can try to check if the Network Key that your typing is correct (If the connection is secured). You can check the Network Key of your router by accessing the Wireless Settings Page of your router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security, You can personalize the Network Key if your want. Save the settings then try to connect.
Rate me if this helps so I can help others.
Thanks for using Fixya.
Feb 04, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
Using Nintendo Wireless Adapter - No Connection Anymore
If available networks are found, it means that the wireless adapter is working just fine. In case of Wi-Fi, the device has to acquire an IP address from the wireless router and the mutual communication is not taking place. This has something to do with the wireless router. Check for any kind of security filtering like MAC address filtering or lower down the encryption technique to 64-bit WEP. Try connecting to even an unsecured network, then check for the automatically acquired IP address. It should never be starting with 169.254.xx.xx (Invalid)
If you have other wireless computers going online in the same network, without security and filtering, then it means that your DS Lite is not acquiring an IP address. In that critical case, you may have to statically or manually assign an IP address in the range of the router.
And lastly, as you said LAN connection is active, it would be because it doesn't face any hardships while connecting!
Thanks..
Do get back if you need further clarifications.
Mar 18, 2010 | Computers & Internet
Hung on connecting to router
Reinstall the computer operating system and then install the adapter drivers.
Nov 05, 2009 | Belkin Wireless-N USB 2.0 Adapter
Unable to connect to internet . wireless connection shows connected at 150 mphs, using repair function seems to hang up at acquiring network address
The wireless access point may have MAC address filtering turned on. This means, that only explicitly allowed network devices can fully connect. This is used to prevent unwanted guests in your network.
You must ask the administrator of the access point or router to add you to the allowed MAC address list. If it's your router, go to configuration and check if the MAC(physical) address allow/deny list is active.
Oct 23, 2009 | ASUS Eee 4G Notebook
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear usb adapter will not acquire ip address from router
Most laptops have a wireless card built in them and if you have one you should try using that instead and form past experiences USB adapters don't generally work on laptops in which case if you laptop has the slot for it you should buy a card like this http://www.netgear.com/Products/Adapters/SuperGWirelessAdapters/WG511T.aspx
Acquiring network address
if you are using the dell wireless utility to manage your card, then disable it, and manage your wireless adapter through the windows network connections. that way the wpa issue will be solved by windows xp wpa. i had a similar problem with my inspiron 1525 (dell wireless 1395)
Jun 09, 2008 | Computers & Internet
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Card does not acquire ip address. repair does not work defaults to 169.254.244.38
What is the network adapter connected to - a modem or a router? Is there any other computer or device that is connected to that modem or router and is able to acquire an ip address? This would generally happen when the network adapter is not able to automatically negotiate with the connected device (which might have 10/100 ethernet ports). You can resolve this by forcing the network adapter speed to, for instance, 100 mbps. Please revert back with further observations.
Apr 16, 2007 | GigaFast Ethernet EE110-AXP (EE110AXP)...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
222 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
