Question about Onkyo TX-SV545 Receiver
I have a Onkyo Tx-SZ545 receiver. Can I connect my iPod to it?
3 Suggested Answers
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
SOURCE: can I connect an ipod to Onkyo tx-ds595?
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
Posted on Sep 25, 2008
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
0 characters
1 Points
Can i connect an ipod to my Onkyo tx-ds777?
You should be able to do it with the right adapter cable.
Jul 21, 2014 | Onkyo TX-DS777
How do I connect my ipod classic to my onkyo tx-sr504 audio/video receiver?
Onkyo DS-A2
iPodĀ® dock
Jul 11, 2014 | Onkyo TX-SR504 Receiver
How do I connect my Ipod classic to my onkyo tx-sr504 audio video receiver ?
Perhaps you just use a cable like this:
24806182-o2xiqwfhpbqb50rejnrszwmj-1-0.png use the tulip plugs and plug them into the AUX of the amplifier. Then at least you can play the music via the receiver.
Jul 11, 2014 | Onkyo TX-SR606 Receiver
Can you hook an iPod up to an Onkyo TX-SV525 receiver?
yes. use adapter cable, connect iPod to an input on the receiver like CD or AUX and select this input on the receiver. See below pic.alexander404_5.jpg
you can buy these adapter cables online or at Radio Shack etc.
Apr 29, 2011 | Onkyo TX-SV525 Receiver
I need to know if it is possibly to plug an iPod into my ONKYO AV RECEIVER TX-SR506?
Yes it is. The easiest way to go about this is to get a stereo mini male to left and right male rca cable. Connect the stereo mini end into your ipod, and the left and right male RCA end into an available input on your reciever. Change the input on the reciever to correspond with the input you connected to. Ensure your ipod is powered on and playing with the volume turned up. This set up will play through your reciever but will not charge your ipod. If you want it to charge while playing, than you will need to get a dock.
Jan 05, 2011 | Onkyo TX-SR506 Receiver
Can I play my ipod through my Onkyo TX-SR600 receiver?
All you have to do is get a 3.5mm plug to two RCA plugs lead and plug the 3.5 Jack in the headphone socket of your ipod and the two RCA's into an aux imput and away you go. If you get one of the small docks, that will stop the battery running down, but you don't need one.
By the look of the picture on FixYa it looks the RCA's can go in the front socket under the volume control.
Mar 30, 2010 | Onkyo TX-SR600 Receiver
Connect mp3 on onkyo tx-ds484 ?
buy an attachment at Radio Shack - Ipod cable to 3 rca cables; plug the rca cables into the
CD input; leave the video cable hanging. It is not a charger, so you will need to re-charge your ipod.
Dec 27, 2009 | Onkyo TX-DS484 Receiver
Ipod Dock connection
The Red, green, blue from this adaptor cable
go into any of the RGB inputs on the Onkyo
The R/W go into the corresponding inputs for audio, Red and White.
One thing to note,
IF you are running one source RGB like you want to do,
you may have to monitor output the video of the amp RGB to the TV, most of these amps do not like to mix HDMI with anything else.
So If you have one HDMI going out to the TV, this solution will not work. You should look at the manual for the Onkyo regarding what paths can pass at the same time. There is usually a small disclaimer in the HDMI section.
Hope that solves your question.
Jan 09, 2009 | Onkyo TX-SR606 Receiver
Can I connect an ipod to Onkyo tx-ds595?
Aug 21, 2008 | Onkyo TX-DS595 Receiver
Bose Cinemateonnect
Hi lechap,
With the indulgence of IB4G2008 as per his last post Feb 13.....
If I figure your concerns right, they are:
1. You have an iPod on an Onkyo IPod dock that you want to connect to an Onkyo receiver TX-302;
2. You have an Onkyo receiver TX-302 that you want to power a set of Bose Cinemate speakers;
3. the connectors on some do not fit or are not the same;
4. you want to know what goes to where.
If I may suggest:
a. connect the L/R Audio Out of the Onkyo IPod dock to the L/R Audio IN of VIDEO 1 using a pair of RCA to RCA cable. Connect the S Video Out of the Onkyo IPod dock to the Video IN of VIDEO 1 using an S Video to RCA Video cable. Thereafter if you want to watch a movie or play music from your iPod, you need to choose Video 1 in the Onkyo receiver TX-302. You can of course choose any other VIDEO 1~3;572fcdc.jpg34ab5d3.jpg
b. all other source/devices may be connected similarly using the same scheme on any of the free VIDEO / AUDIO inputs
c. of course the MONITOR OUT goes to your TV or projector.
With respect to the Bose Cinemate, it would not be technically correct to connect the Bose Cinemate speakers straight to the speaker out of the Onkyo receiver TX-302. You need to install another set of speakers to the speaker outs of the Onkyo receiver. The Bose Cinamate system's TV AUDIO could be connected to the TAPE OUT (or the AUDIO L/R OUT of VIDEO 1)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 13, 2008 | Onkyo TX-SR302 Receiver
Audio & Video Receivers Logo
71 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
