Question about Technics SA-AX540 Receiver
Technics SU-G91 Left channel bad
The left channel for A-B has poor sound. I get sound but it is very distorted and not very loud. I have tried soldering the joints on the relay but had no results. I have check the speakers and the signal coming in. The right channel work just fine. I have a Technic Amp model SU-G91. Please help.
  • lococ Mar 09, 2008
    I still have not found the solution to this problem.
  • Anonymous Feb 21, 2009
    same problem. Any help would be appreciated.
Man what is iut with Technics and the left channels? I've had 3 amps and all three blow out the left side after a few years.
Posted on Mar 06, 2008
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Posted on Jan 23, 2008
My Technics SU A700 mk2, doesn't have any signal in right channel. During (i am first owner)time I noticed that I had that right channel performance reduced arround 15% compared with the left one. ...
Have you tried cross-plugging the speaker cables (i.e. swapping left and right channels) to be absolutely sure it is the amp ? I have a speaker that needs a fair amount of volume to wake it up, but after that performs well.
Jun 15, 2017 | Cameras
Technics 1310 turntable has left channel (white
There are just two causes, one is the preamp, which can be easily checked by putting the right channel jack in the left terminal. If the sound is normal, then it's likely that the cartridge in the deck is bad, or some wire is loose. However if the sound is still poor then the magnetic cartridge preamp in the amp has a fault. These are normally a single IC, which will have failed. Find the preamp by tracing the wires from the imput socket to the PC board, which may be alone.
Mar 21, 2010 | Audio Players & Recorders
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
I have no sound in teh left channel , could be an integrated ?
Hey, The model of the amplifier is SU-G91 Technics.....If you could help......Thank you.
Apr 08, 2009 | Technics SA-EX320 Receiver
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
Channel has switched off.
Make shure speaker wires are not crossed at amp or at speaker terminals. Check balance control is at center. Check sound with headphones to see if final amp to speakers is the problem. Try switching imputs on back panel from right to left see if same speaker is on,.Try all loudness controls and tape dubbing buttons to see if any are dirty.
Good Luck
BIG RED
Nov 03, 2007 | Audio Players & Recorders
Technics SA-AX540 Receiver Logo
845 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
