Question about ASUS A7V8X Motherboard
LPT port For csome reason my printer port has stopped working. I navigate to device manager/ports (com/lpt) and no lpt port is showing Hope you can help regards Noel Hunter [email protected]
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Now you have to insert the System CD of the motherboard and when it auto run then install ALL the driver its shows and if the problem countinue then install the port manually using ADD NEW HARDWARE in th control panel.
Posted on Jan 06, 2008
SOURCE:
Trying to add a printer to computer via usb 2.0 printer cable
plug your printer into any usb input point on your computer
found new hardware wizard should start or you might have to do it manually
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Feb 14, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
The printer will not print, however the on switch is showing on but the screen display is not showing any data at all. The printer will not switch off or print.
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
May 13, 2011 | Computers & Internet
Printer just not working
hope this helps
dont forget to vote
Feb 14, 2011 | Dell 946 All-In-One InkJet Printer
Tried different ports, different usb cables. No luck. It shows in the devices but will not print
Check for the printer requirement for operating system and maybe it is not compatible.
Correct Printer icon name. Correct usb port driver needed. Check your device manager for usb port driver if properly installed. otherwise use LPT port if there is install driver for your computer.
Dec 16, 2010 | Office Equipment & Supplies
Printer just stop working
control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Dec 06, 2010 | HP PSC 1610v All-in-One Printer
All usb ports stopped working.
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
hope this helps
Nov 22, 2010 | ASUS M2NBP-VM CSM Motherboard
When I turn on my printer it wont load and the hour glass runs constant
you might have to unstall then reinstall it
control panel add and remove programs select the printer to uninstall or the printer might have its own uninstaller click start all programs navigate to the printer and see if it has its own uninstaller
or you might have to install drivers
control panel admistrive tools,computer management,device manager scroll down you could see a yellow question mark? right click to reinstall drivers or ports(com&lpt)+ to expand then you will see communications port or ECP printer port right click update driver
hope this helps
Nov 15, 2010 | HP PSC 2410 All-In-One InkJet Printer
CANT GET PARALELL PORT TO WORK DEVICE MANAGER DOESNT SEE IT ?
the laptop bios should support lpt port and if your doesn't have lpt port then you can not use the one for the docking station because no bios integration with the lpt port on docking station
Apr 18, 2010 | Targus Port Replicator, Docking Station,...
Sometimes when I'm printing, it will stop printing and show DATA PCL on the screen. I shut it off and back on and it prints garbage.....how can I fix this?? thank you
Try this if connected parallel:
This error may occur if you have a computer with an ECP port in Windows;
INCOMPATIBLE PARALLEL PORT PROTOCOL: During the PLUG n PLAY setup, Windows usually sets the parallel port driver for ECP mode if the computer's hardware port is set for ECP or, in some cases, ECP+EPP. Windows 95 will utilize data compression during ECP data transmission which can cause "garbled information" if the receiving device, such as a printer, is not ECP compatible.
SOLUTION:
Change the Windows Operating System's printer port driver (LPT.VXD) to the standard mode (non-ECP).
Windows XP:
1. Click on "Start", then "Control Panel.
2. Double click on "System:, and click on "Hardware", then click on "Device Manager"
3. Click on "Ports (COM & LPT)" section, and click on "ECP Port".
4. Click on "Driver", then "Update Driver"
5. Click "Install from List or Specific Location (Advanced)", click on "Next"
6. Select "Don't search - I will Choose Driver to Install", click "Next"
7. Select "Show Compatible Hardware"
8. Select "Standard Port" on the left window and "Printer Port" on the right window
9. Click on "Next" and Click on "Finish" and close all windows
10. Reboot/Restart your computer to ensure the changes are activated.
Mar 26, 2010 | OKIPAGE 14ex Led Printer
My com port disappeared
Yeah such problems happens when com port versions are mismatched with OS supporting drivers.
So in that case, you should repair you OS or restore it to FACTORY settings.
By doing this you will be able to regain your all configuration for all ports available.
I hope this will work out for your problem.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Toshiba Satellite P15-S420 Notebook
ASUS A7V8X Motherboard Logo
252 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
