Question about RCA TH1011 MP3 Player
RCA TH1011 MP3 player
My RCA TH1011 Player turns on, but wont' go past the welcome screen to play the music. It has a fresh battery, so I'm not sure what the problem is.
After it is turned on, you need to push the power button again to begin playing....To shut down, hold the power button....
It's not the best player!
Posted on Mar 18, 2008
SOURCE:
I can play the mp3 files from the device on the
I suspect the new format is not compatible with at of the player. The manual says the the player should only be formatted to "FAT" . If it has been formatted to FAT32 or any other FAT. Then it will only work as a hard disc. You should change it back. However the manual does say that changing it over (frequently) can cause permanent damage to the unit.
As this seems to have been designed to work with Windows 98, or XP you might be able to ask the Windows 7 Computer to treat it as that.
Jun 19, 2017 | RCA TH1011 MP3 Player
My mp3 playa wont come on
I have the same unit, which I think was great value for the money, but occasionally it refuses to start up (it hangs at the welcome screen) or doesn't play certain tracks. Whenever it acts up, the solution has been to reflash/upgrade the firmware.
Download the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
  1. start the program,
  2. remove the battery,
  3. hold the play button while plugging the RCA player into your computer's usb port,
  4. release the play button when the term "initalizing" replaces "searching",
  5. check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
  6. click the start button to replace the firmware.
After I did this, I was also able to play DRM-protected and aac audio files. I hope that helps.
Nov 10, 2009 | RCA TH1602 MP3 Player
My mp3 player turns on and turns right back off,and it wont turn on when i plug it up to the computer
I have the same unit, which I think was great value for money, but occasionally it refuses to start up (it hangs at the welcome screen) Whenever it acts up, the solution has been to reflash/upgrade the firmware. This works even when plugging it into the computer seems to have no effect.
After I did this, the computer recognized it again and it started like normal. I hope that helps.
Oct 01, 2009 | RCA TH1602 MP3 Player
The player turns on but will not go beyond the welcome screen - how do I correct this problem?
I solved the problem myself.
I removed battery, inserted a new one and it worked properly.
Thanks for your help.
Oct 01, 2009 | RCA TH1011 MP3 Player
Wont load past the "please wait" screen
Check to see if the player needs a firmware update or if there is a reset on it. Also try different USB ports on your PC to see if when you plug it in it recognizes the player and maybe needs firmware. If you have more trouble try the RCA website or call customer service. Good luck.
Vic
Mar 04, 2009 | RCA TH1611 MP3 Player
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
Jan 06, 2009 | RCA TH1101 MP3 Player
NEED THE APLICATION
You can get the latest downloads, register your new RCA product, check
out the FAQs or find an answer in the User Manuals. Product How-To
Videos, Forums and Step-by-Step Solutions will be coming soon.
TRY IT ...........
Dec 20, 2007 | RCA TH1011 MP3 Player
Memory card question
It should read the songs automatically. Once you have inserted the card with MP3 Format or WMA formatted songs it should read it.
Apr 17, 2007 | RCA Lyra RD1072 MP3 Player
My lyra wont turn on
Take the battery out and then put it in again and it should work again
Aug 15, 2006 | RCA Lyra RD2820 20 GB MP3 Player
RCA TH1011 MP3 Player Logo
164 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
