Question about Sony KV-32FS13 TV
No Picture, no sound, spinning up noise
MY six year old Sony TV will turns on, though has no picture, no sound, and shuts itself off after a couple of seconds. While the tv is on, there is a high pitched, soft, intermittent noise, almost as if something is trying to spin up. The standby light blinks four times.
In the past couple of days, the TV would be on for a while (half hourish), then turn itself off. After unplugging for a minute and replugging, the set worked. This no longer works.
It has been a great set, and I don't feel like it has lived out it expected life! Is it worth fixing? Is it fixable by a fairly tech savey novice?
Thanks for your insight.
  • Anonymous Dec 09, 2007
    I have excatly the sameproblem after 7-8 years
  • BobbieK Dec 15, 2007
    Pretty much the same thing. After 6 years it made a really loud noise then the picture changed to just a bunch of lines...then no power. Each time I turn it on I get the same thing for a few seconds, then nothing.
    I have not even attempted fixing it yet. Is it worth it??
    Problem Solver:
  • 19 Answers
Vertical ,horizontal or power suppy
Posted on Dec 02, 2007
SOURCE:
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
I have a sony Vega 55" kdf-e55a20, It is 3 years old, and now the picture and sound fade away for 10-15 sec every hour or so and comes back! Anyone knows what the problem is?
Lamp is getting weak and TV shuts off and turns on itself because of weak lamp in TV that you see picture and sound fades away for some time until TV reboots.
Replace lamp in TV to solve this issue. Lamp replacement procedure is written in user manual and its an easy work.
Please buy Sony original lamp for your Tv safety.
Thanks.
Dec 23, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture shuts off
It seems as though the bulb(s) in your unit are about to go out. This is repairable/replaceable by calling your manufacturer. If you are still under warranty they can help you by possibly troubleshooting/replacement/referrals.
Aug 06, 2009 | HP Md5880n 58 in. HDTV
Tv shut itself off while I was watching.
The power supply will need to be replaced. You can get them for $30 plus dollars and solder them in.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Sony KV-32FS13 TV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
