If I use my tv for a while and don't turn it off it works fine, but if after watching it for a while I turn it off and a few minutes later I want to turn it back on it does not turn on. I have to unplug it and wait a while before I can plug it and turn it back on...
First you want to unplug the tv for a few hours to reset settings. Plug it back in and then switch the master power switch off and then on.
There is a master Power Switch next to the power cord receptacle, make sure that this switch is on the on position and the blue LED in the front is illuminated (Note: The switch in the rear of the television is in the on position when the line is depressed).
This should get your tv working again. Just needs a good powercycle.
TECH just worked on a tv I just tried it on.
SOURCE: My Olevia 26 inch LCD works for 2 minutes then screen goes out.
It is most likely the Inverter Board. You can buy them online. The Olevia company got bought out and the only way to have them repaired is by sending it in to a repair shop and they have to send it to this company that is repairing the Olevia models (this is the ordeal I had to put up with) I asked him if I could send it to them but he (in an indian language I could hardly understand) told me I COULD NOT. It is a joke. I repaired my 30" (LT30HV) with the inverter board I bought here ( http://www.lcdparts.net/InverterDetail3D.aspx?ProductID=2510 ). It was $149.00 and they have instructions and pictures on how to repair it. You will have to have basic electrical knowledge as to what goes where when you put it all back together again. Other than that, it took me about 35 min (had to figure out where all the screws were) to take apart, 5 min to take the bad board out, 2 min to install the new one, and 15 min to put it all back together. Good luck
same here
I always have to slip the switch in back on and off several times and push the power button in front several times before it will finally turn on. It's works great once its' on.
yes mine too. It seems as if it is warm (Warmer then room temp) it turns on quickly. It in the morning cold. You will be sitting awhile pushing th power button
same problem
sucks, dosn't turn on
Now, I am getting the same problem too... Never once had this issue before really... It has just now started turning cold outside, but it is warm inside. I press the power button, the red light flicks off for a few secs, then pops back on. Nothing happens. No visuals on screen, nothing...
same problem w/ Sabre LCD TV
I have the same problem. Was anyone able to fix it themselves? Please help, do not want to buy another one when this one is still new!
Having the same problem. Has anyone fixed this yet?
TV will not power on. It makes the sound, like its about to turn on, and then doesn't.
