Question about Canon i850 InkJet Photo Printer
Reset following paper jam
After paper jam I followed all procedures per manual but cannot get printer reset. Still get red light flashing 3 times.
    Scholar:
  • 103 Answers
It sounds like a bad paper sensor and the printer needs to be serviced. Your only bet is to try to clean it out.
Posted on Apr 23, 2008
SOURCE:
Paper jam
Try reset your printer by following this procedure to reset it,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold # and 6 keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
Or
. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state. This should fix the problem.
Sep 16, 2011 | HP Office Equipment & Supplies
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
I'd tried to fix my brother dcp-120c printer, it was unable to print. i followed the instruction of troubleshooting manual but i cant fixed it. the flash display on my LCD is MACHINE 5A. What will i do?
The machine does not work due to a paper jam or some sensor problem.
Clear the paper jam. If the problem still continues after clearing the paper jam, try to clean the encoder strip behind the printer head.
Also, try a reset:
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 15, 2011 | Computers & Internet
The power light blinks red! it can't turn On!
"If your 8002/7002 goes into protective mode (red power light flashing at two times per second) the receiver will not operate until it is reset. First try the reset procedure on the bottom right corner of page 81 in the manual.
If that doesn't work, press and hold the following three buttons on the front panel until the unit resets:
Pure Direct
7.1 Ch input
Clear
This latter procedure is not in the manual and I can't fathom why, as it can save the inconvenience of a trip to the service center."
Feb 03, 2011 | Marantz SR8002 7.1 Channels Receiver
I set up my own wireless network and now my printer will not communicate with my laptop.WIFI light flashes red. Have tried everything to reconnect. Lexmark Z2420.
I suggest you reset the Lexmark Z2420 wireless network adapter. To reset, do the following: With the printer on, press and release the power button. The printer will enter power save mode. Now, press and hold the paper feed button. While holding down the paper feed button, press and release the power button. Continue holding the paper feed button for 30 seconds. Release the paper feed button. This will reset the internal network adapter (INA). When the printer has been reset, a solid orange Wi-Fi indicator light should appear. If Wi-Fi light goes back to flashing red, you have not successfully reset the printer. Start the procedure again. Once you have a solid orange Wi-Fi light, reconfigure the printer for wireless connection. Thanks.
Jul 29, 2010 | Lexmark Z2420 Printer
Printer won't print. Flashing red light. No paper jam and ink cartridges are ok. Please help!!
Per the manual, it's 99.9 % one of these causing the issue. The other .1 % should take it back or get a new one.
The printer requires attention. Try the following:
● If the printer is connected to a computer, check the computer screen for
instructions. If the printer is not connected to a computer, check for the following
problems:
– Top cover open
– Out of paper
– Paper jam
– Print carriage jammed or stuck
– Print cartridge inserted incorrectly
– Incorrect print cartridge installed
● If you are unable to solve the problem by using the instructions above, turn off the
printer and unplug the printer's power cord. Wait one minute, then plug it in again.
Turn on the printer.
Sep 29, 2009 | HP Photosmart 7450 InkJet Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Paper jam
try this
Open up the printer as much as possible and turn it upside down and shake it (be careful with the scanner lid though). See if anything falls out
or this service mode
  • Turn off the printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for three times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • May 26, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    Error code e-3
    Mp150 Reset Counter
    Service mode operation procedures -
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
    the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
    service mode. (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
    function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
    orange and green, starting with orange.)
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset See waste ink counter reset
    procedures below.
    5 times Orange Destination setting See Destination setting
    procedures below.
    6 times Green Print head deep cleaning
    11 times Orange Button / LCD checking
    12 or more times Returns to a menu selection
    Oct 02, 2007 | Canon PIXMA MP150 All-In-One InkJet...
    Red Paper light keeps flashing
    Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
    Oct 02, 2007 | Epson Stylus C86 InkJet Printer
    Canon i850 InkJet Photo Printer Logo
    70 people viewed this question
    Clive
    Clive
    old marine
    old marine
    Ekse
