I have problems with VB6 Make .EXE command: I have witten two projects in VB6, let's call them project1.vbp and project2.vbp. Both run fine in the IDE. I can compile projet1.vbp using the Make Command from the File Menu by clicking on File > Make Project1.exe. But when I try that with project2.vbp the .''exe'' is missing from the Make command. It just says Make Project2. Why can't I create a Project2.exe?
I guess your compiling logs are absent, or have been corrupted, which are only used to when you publish/make an executable.
To Confirm this, Make your EXE through Command Line Compiler, and How See this
If its still not working and your Project is important, then make a blank project and copy paste all Source and Objects there.
Regards,
Waqar.
