Refrigerators Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a side-by-side with water, ice cubes, and crused ice things on the door. We can get water at the door but there is not ice. The icemaker is working thru the cycle but there seems to be no water going into the part that makes ice. Any ideas?
Anonymous
Level 2:
Sergeant:
  • Expert 193 Answers
  • Posted on Aug 18, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
193
Questions
0
Helped
56169
Points
572
One of the most common causes is that the line has frozen, unplug the water line from where it enters the freezer (turn off the water first) and see if the line is iced over (may have to open the freezer and look from the inside after removing ice maker to tell for sure). if not, the next thing to do is check to see if the ice maker is calling for water. to find out set a voltmeter to the 12 volts dc range and check to see if there is any current on the water solenoid valve at the point in the cycle where the ice maker should fill. if there isn't either replace the ice maker (faster and easyer) or replace the ice maker's timer. unless you have a local shop you like i recomend parts from here: http://www.appliancepartspros.com/partsearch/
Anonymous
Level 2:
Scholar:
  • Expert 61 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
61
Questions
0
Helped
17885
Points
162
I would immediately check the ice maker area and look for a little tube (usually black and about an inch long). Once found, try to flex or bend it and if it's stiff, more than likely the line is frozen and ice is plugging up the line. Just take out your good old blowdryer and blow the area on high heat for a few minutes. Soon and hopefully, you should start to see some water slowly dripping out of the tube and eventually, the frozen ice core will slide out of the tube. Finally, wait a couple hours of so and see if you have any new ice.
I Can Fix It
Icemaker is not making ice cubes. fridge is 3 months old.
Well if your ice cube bucket is on the freezer door it self then it could be anything from the optics system to a bad icemaker to a water valve issue...if its located on the side freezer wall. the water valve could be bad or the i/m module/icemaker
Nothing is cool no ice or anything but the fan in the freezer and the fan bottom rear are working continuously
If your icemaker is producing small cubes, hollow cubes, huge cubes, or a solid slab of ice, one of the first things you want to check is the fill level. And it's not as difficult as you might think. (Hey, the hard part's wrenching that bottle out of Pookie's little fingers!) Unplug the refrig, pull the icemaker - usually one screw underneath, either 2 more or hooks above the cube mold - and unplug it. Take it to your sink and melt out any cubes with hot water. Then plug it and the refrig. back in, leaving it unattached from the freezer wall.
Manually start a 'harvest cycle' (see below) and hold Pookie's bottle under the fill tube. You'll have to wait a few minutes, because the water enters near the end of one complete rotation of the cube ejector, which constitutes a 'harvest cycle'. Regardless your type of icemaker, you're looking for 130-150 cc's, with most working best around 145cc's, but anywhere in this range should work OK.
(When replacing your icemaker with a new one, always check and adjust the water fill level this way too. You'll save yourself a lot of trouble.)
2helpful
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
1helpful
MY ICEMAKER IS STUCK IN THE CRUSHED ICE CYCLE WONT PUT OUT THE CUBED ?? EVEN WHEN I PUSH THE BUTTON BACK AND FORTH WONT SWITCH ??
if you have selected cubed on the door and still wont dispense cubed ice likely cause is the cubed ice solinoid( located behind the panel in where the auger motor is located) thats the motor that turns the curly thing in the ice cube resivoir.....!!!
Ice cube maker not making ice
feel with your finger on the inside of the icemaker to see if you have water or if there is the presence of ice if you have water or ice on the inside of the ice maker then replace the icemaker if you dont have water or ice then check the valve in the rear of the machine to see if your getting water to the icemaker
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
The freezer door was ajar overnight and now the icemaker is leaking water
chances are alot of the ice melted overnight. remove all of the ice cubes, dry everything out and then wait a full 24 hours for the icemaker to produce ice cubes.
No ice being made
Pour about 1/2 cup of water into icemaker . If it dumps the cubes but does not fill with water , replace the water valve ( the part that the line from the wall connects to on the fridge ) . If the icemaker does not dump the cubes , replace the icemaker . Be sure the coils are clean of dust , lint , etc... as this will not let the freezer get cold enough for the icemaker to dump .
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
