Question about Altec Lansing ATP 3W Computer Speakers
The speakers they are connected properly but it wont show on the computer that the device is attached so how can i get them to work?
    Problem Solver:
  • 10 Answers
I am asuming these are usb speakers then I would check my usb port to make sure its ok try pluging in somthing dif that is usb if you have not already tryed this
Posted on Dec 02, 2007
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
How to connect a soundbar
Very carefully! When you purchase a Sound bar the inserted directions show you the proper attachments. There is no mention who manufacture the speaker and how you wish to use it. Computer, TV, DVD or what?
Dec 14, 2013 | Audio Players & Recorders
Speakers will not work on e machine et1331g but are installed
Hi,Dear User..Flow instruction:-
1> Check you speaker all connection point.2> Check you connect speaker lead out put Point.3> Power point Check to speaker.4> Installed Audio driver to mother board. Not any other Driver install only proper driver.5> If driver install then check it. a> Go to control panel- Add or remove program, hear show audio driver or not. if not show then install.
b> My computer right click- property- hardware- device manager, if audio point yellow then install driver. if not yellow then install driver.
6> If all thing check then you speaker not support in you PC.
Note:- Batter then Contact good Computer Hardware Engineer.
More Computer Support.
Thanks...
Feb 13, 2013 | E-Machines eMachines Desktop PC
My speakers are not working. I made sure everything is connected properly. The speakers do not even show up under my sound device panel.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 05, 2011 | Dell A215 Computer Speakers
Wont turn on or play a single sound
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty graphics card clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 27, 2011 | Gateway Edison Computer Speakers
Connected this dual speaker to my cmpact desktop comp and it does not want to work
First step is to assure that the speakers are working. If you have no other computer or sound system to test the speakers, then attach a AA, AAA or C battery to the speakers plug. It makes no difference in the polarity. If it makes a horrible white noise, the speakers are in good working order, if it makes no noise, the speakers are at fault. Should the speakers be ok, then in all probability you have a configuration problem. Go to control panel, select Sound and Audio devices, and check that the proper configuration options have been selected, and that the speaker volume sliders are at least at the 50% mark. If this doesnt solve your problem, then a computer motherboard component might have failed. Keep me posted
Mar 12, 2010 | HP JBL Platinum Computer Speakers
Problem for computer speaker
hi chaitraraj,hope you connected the cables in the ryt connectors if yes does your pc show volume level indicator?if not you have to reinstall the audio driver of your motherboard.let me know if this helps.
May 11, 2008 | Acer (AV120) Computer Speakers
Sound
did u install sound card drivers
if u install correctly go to control panel and sound
check there whether audio device is showing or not. if not u didnt install ur audio otherwise u installed correctly but the problem is in ur speaker.
Feb 23, 2008 | Logitech Z-3e Computer Speakers
Speakers in monitor wont work
hi there, 1st check the connection of cable speakers. then check the volume control, switch it mid range setting. then check the hardware device if there is no conflict with any device. try to reset your system once again and if still same problem, you may have a Speaker problem, maybe the connection inside your monitor with the speaker has a loose connection or some electronics part failure. TY
Dec 23, 2007 | HP vs15 15"LCD Flat Panel Monitor
Altec Lansing ATP 3W Computer Speakers Logo
56 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
MegaByteMe
MegaByteMe
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
