Maxtor DiamondMax 60 (33073U4) 30.7 GB Hard Drive Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Seagate maxtor n256 not recignised
My Optiplex GX110 Is't recignising my seagate maxtor n256 internal hard drive and i don't have the disk to re-install it with and my computer won't start up.
Anonymous
Level 3:
President:
  • Master 1,126 Answers
  • Posted on Aug 18, 2009
Anonymous
Master
Level 3:
President:
Answers
1126
Questions
0
Helped
563489
Points
3418
Need pin setting for N256 HD by Maxtor
Read the printed label gummed onto the top of the disk-drive, for the possible settings:
* MA(ster)
* SL(ave)
* C(able) S(elect)
Try the 'CS' position for the jumper, and connect the drive.
Harddisk fail! but BIOS recognize that as Maxtor .
Is this a primary HDD?
have you checked the jumper?
You can also try to reseat the HDD cable
13helpful
2answers
1helpful
DELL Optiplex GX110 freezing
Check the settings of the internal setups. This is using the BIOS itself and hitting a particular key before anything happens. On some machines it is F1 or the DEL key. In the basic setup there are settings for the boot order and floppy drives and HD type. Make sure these are set correctely.
ALSO on one of mine I have to use a formatting/partitioning program supplied by the HD manufacturer (in this case Maxtor) to pre-prepare the drive beofre trying to install WIndows.
My Lacie hard drive is not working
It Seems to me like when you unpluged it without properly ejecting it, that it partly corrupted the part of the ext. hard drive that is recignised by the pc to then recignise it and make it ready for you to use.
If it uses a power adpter to power it plug that in first, then plug it into you computer, and see if that works.
I hope I helped.
Yours,
cjpipod
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Not finding what you are looking for?
    Top Maxtor Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
