Question about Sony PlayStation 2 (PS2) Console
Disk won't spin
My ps2 won't play any discs and when i put a disc in the only thing that moves is a little moter that helps to open and close the CD tray. This is a fat ps2. It doesn't even try to read the disks.
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Have you try-d cleaning the lens with a cheep cleaner ((disk type)) some times a can of compressed air works to blow the junk out.OPENING IT YOUR SELF LAST RESORT . but if you have to ill make ya video on how to replace it.
Posted on Dec 02, 2007
SOURCE:
My PS2 wont spin the disk or play it and when ever I turn it on it comes up with Browser or System Configuration
Hello
The problem seems to be your laser, It sounds like it is not reading the disc.
You need to do 1 of 2 things.
1st if you cam give a quick strong blow into the disc tray when it is open, to remove any dirt and dust from the laser area.
2nd If you can get hold of a laser cleaning disc and use this to clean your CD/DVD drive. Just insert the disc and let it play for 5 mins. You can get these discs from almost anywhere, try your local supermarket.
Hope this helps
Mar 06, 2011 | Sony PlayStation 2 (PS2) Console
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
DISK NOT SPINNIG AT ALL !
the stepper motor in yur ps2 has a either a wiring problem or it is disconnected.. please chec that.
Jul 07, 2009 | Sony PlayStation 2 Slimline Console
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Audio Players & Recorders
Ps2 slim says disc tray open off and on during gameplay
you are very genious man u think so u put heavey weight on ps2 so you have to put out your cd tray than with helpo of screw driver you open your console than take a tiny thiner than put at this tray of ribbion than wash and clean our disk tray than got new rubber band and some grees and than close your console any try again inshallah you got good result
Dec 31, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 wont read the disk. says there is no data. help
it's your laser with something like dust keeping it from reading the discs. Just get a simple CD cleaner kit, one that has the little brush on it and then of course put some solution on it. Rubbing alchol will due. This happens to everyone eventually.
Should do the trick.
If it doesn't do it after playing the cleaning disk three times for around 10 secs each, then you may want to open it up and put clean the laser lens directly with a rubbing alchol soaked que tip and a dry one. For more instructions on how to open it do a search on fixya and there is one guru who goes into great detail about this.
Dec 27, 2008 | EA - Electronic Arts Rock Band
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 Not spinning disc
ok you hav ridep a motor ribben replase and it should work
Nov 27, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slim New Lens, Not Spinning
Hi guys,
Well, there is 2 switch. one at  the back left of the cd tray and one one the reset /power switch. both sitch have to be close in order for the disk to spin.
If you try this dont forget to put a disk on the spindle as you will start the laser. this is for your safety. then, if the disk does not spin, then you can try replacing the laser. or at least verify the ribbon cable that is hook to it. if the ribbon cable is not well inside the plug the laser might move but again the disk won t spin.
it is related to each other, the PS2 seem to verify the laser prior to start the spindle so what ever happend to the laser affect the spindle.
and then, if you buy a new laser lens, don't forget to remove the soldering bridge. it is a small ball that is use to avoid static while shiping the lens.
most of the seller will include a small peace of paper with procedure and also there is web site with picture of this soldering bridge.
I replace some of them, and I have to say that the small plastic lock for the ribbon  cable to the lens has been an issue and the soldering bridge another one.
but I got most of the PS2 back and running by replacing the laser.
I hope this will help you.
Feb 26, 2008 | Sony PlayStation 2 Slimline Console
Why does my ps2 play cd-roms (blue discs) but not dvd-roms
After extensive research on this subject and working on several Playstation II systems. I found out the reason your system will play only blue disks and not silver is a alignment problem with the laser. It could be tilted or set to high or low. The quickest solution is to call Sony and get a new laser with the shuttle. If i am not mistaken it cost 50.00 and just go to the playstation site select support and it will explain in full detail how to take your system apart and replace the laser and shuttle.
Sep 16, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
