Question about Canon PIXMA iP4000 InkJet Photo Printer
Pixma IP4000 12 flashing lights error 6A00
I know its a paper feed problem , but there are no jams must be an electronic fault ?
any suggestions
  • 3 more comments
  • Anonymous Feb 27, 2008
    Im having the same problem, the sheet drops down but wont feed.
  • Anonymous Feb 29, 2008
    IP4000 12 flashing lights error 6A00 problem,
  • mustangsa38 Jan 17, 2009
    I have the same problem But I have a pixma ip3000, I changed the print head (was getting 5 flashes) the ink tanks are full. Still wouldn't print (it was going through the motions of printing but no ink on the paper) I had read that it could be the purge unit or tubes might be clogged, so I took the printer apart looking for the purge unit. I found the tubes (4 of them) I removed them to clean, but there wasn't any ink clogged (put them back) Turned the printer on and now I get 12 flashes - I can't find anything that refers to the 12 flashes on a pixma ip3000 - please help
  • hsxnl
    hsxnl Apr 22, 2014
    Add a CommentError 6A00: AP position error. The printhead controller cannot position the print head correctly. This can be caused by [1] a blockage (by the purge unit), [2] lack of grease on the carriage shaft, or [3] a damaged timing strip (QC1-4284-00 - Film Timing slit strip), or [4] a defective sensor (in carriage unit). In my case, I found some ink on the strip, obscuring some of the slits, causing the fault. The strip is easily removed and cleaned (with warm water and soap or IPA using a soft tissue). Replacing the cleaned strip resolved my 6A00 problem.
  • hsxnl
    hsxnl Apr 22, 2014
  • 10 Answers
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Posted on Dec 30, 2008
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Posted on Feb 29, 2008
PIXMA MP780 All-In-One InkJet Printer: Getting Printer Error 6A00 light on pinter flashin...
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6A00 green and yellow lights are flashing. Printer will not print.
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Fault/error 6A00 for my canon MP830 flash light and no paper (fault) roller defect can I fix this ? John
6A00 is AP position error.Possible problems in:
- Sheet feed unit (QM2-1220)
- Logic board assembly (QM2-1520)
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Alarm light flashing and a 6A00 error code
Ok try this
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Sep 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My printer keeps showing an error 6A00 on LCD screen
There is one solution you can reinstall software of printer
May 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP850 error code 6A00 flashing lights. no
Hi
Solution 1:
Solution 2:
Solution 3:
Mar 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer Canon Pixma MP830 will not print
Hi
You can try
Solution 1:
Solution 2:
Solution 3:
Mar 08, 2009 | HP LaserJet 1012 Printer
Canon M P 800
Hi
All the best
Solution 1:
Solution 2:
Solution 3:
Nov 17, 2008 | Canon Pixma MP800 All-In-One InkJet...
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00
I just had the same problem :( I dont have a true fix, but I slid out the cartridge to the left and back in. I read it had to do with a timing mark somewhere. When I powered it back up. It went back to normal
Jan 22, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
1,813 people viewed this question
old marine
old marine
