Question about Keurig B70 Coffee Maker
Watery tasting coffee
Help - we are on our second machine in less than a month. First machine was watery coffee, tried about 20 k-cups and ended up exchanging machine. Second one was perfect for about # weeks and here we go again, watery coffee & tea. We use deer park spring water in it only. I am at a loss. Help. We use the machine everyday.
  • Daniel Taylor Mar 02, 2008
    I have been using a b100 for years, but eight months ago it started taking longer to brew and then the coffee is so weak.  It is pouring a little less than 6oz. and it seems hot enough, but it's really watery!  All sorts of k-cups tried to the same results.
    I tried replacing the air pump (I know someone who worked at Keruig) but that didn't help at all.
    I wish I knew what was wrong... Keurig is no help, they want me to send in the k-cup cradle and they'll give a discount for another (cheaper, made in China) model.  Um... no.
    I will never throw it away; it's a masterpiece.  Made like a brick s*house and made in the USA.  It'll just collect dust until someone posts a solution!
    Please, any thoughts or suggestions?!?
Have you tried cleaning it with the 64 ounces of white vinegar?
Read your booklet if you still have it. Pour the vinegar in run it through until it ask for more water to be added and just let it sit overnight or at least 8 hours. Then flush it out with fresh water at least two or three of your water tanks should do it. Then give it a try again.
Just a suggestion if you haven't tried that yet. Hope it helps.
Posted on Jul 23, 2008
  • Misty Page Aug 25, 2013
    I have done this descaling more than once and it still does this. Good luck
Coffee only comes out in spurts (not the usual free flow) and tastes watery
How to resolve Saeco Odea Go Issues - YouTube
? 6:29
https://www.youtube.com/watch?v=lRl_D5lBm5s
Apr 27, 2011 - Uploaded by slashtiger1
This video will explain how to resolve the 'dripping coffee' issue and similar ... I am a ******** espresso ****** and my machinehas been down for several weeks. ... and doing the steam outprocess, it still was not pumping out coffee. ... only to brew with the smallest quantity of water, you could try cutting ...Missing: spurts ‎usual ‎free ‎tastes
Jan 12, 2016 | Saeco Magic Comfort 103467 Espresso...
Coffee tastes bad in old and new coffee makers
Have you tried first just running distilled water through it, then again with spring water and then test with enough coffee for 1 cup to see how the cofee taste then. Also you may want to use distilled or spring water when making that one cup of cofee to test.
Dec 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
My coffee tastes very watery......same settings as usual. I am getting a full cup so it is not clogged.......
Hi, Bottom needle in K-cup holder is either plugged or missing...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 30, 2011 | Keurig B60 Coffee Maker
Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Microwave Ovens
Coffee just drips out of machine, have left off over nite, worked fine now just drips & we get only about a 1/4 cup. Have not desaged as is only about 6 months old?? Bob Spackman
wer
Dec 25, 2010 | Keurig Platinum B70 Coffee Maker
Brews about half a cup of coffee. i have tried the paper clip many times
Dec 25, 2010 | Keurig B100 Coffee Maker
When k cup is placed in machine no coffee comes out, with out k cup water comes out
sfd
also clean the holes at the bottom of the k cup holder
Dec 24, 2010 | Keurig Platinum B70 Coffee Maker
When ever i try to fix a cup of coffee and put the coffee in and try to brew it it just trinkles out. so can you help with my problem?
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
Espresso is dark and rich at first; then shifts to water
This is suppsed to happen, every espresso machine out there on the market does this.
All the taste for the coffe comes in the first couple of seconds and after that it gets less and less.
So the problem is not that it gets lighter and lighter, but that you dont get enough taste in the start of the brewing.
And this can be caused by alot of things.
Bad beans?
Not set the grinding to fine?
it will not heat enought and thereby not get enough taste.
etc.
Apr 12, 2008 | Saeco Talea Giro Espresso Machine
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Keurig B70 Coffee Maker Logo
676 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
