Question about Jensen VM9510 Car DVD Player
Hey i want to know go to bypass the ebrake or where do i connect the yellow wire
You need to put a code and its
Posted on Dec 02, 2007
SOURCE:
My remote wont work on my jensen uv10 and i want to bypass the parking brake. Can you tell my how to do it without remote. Thanks
You don't need the remote to bypass the ebrake withe remote use a tago switch to bypass the ebrake hook it up to the pink wire on back of the deck.
May 04, 2011 | Car Audio & Video
How to by pass the e brake wire
at this time there isn't a code bypass for this model. the easiest thing to do so that you can play video while in motion. is to put a toggle switch on the parking brake wire of the dual screen. then do the ebrake pattern on the switch instead of the ebrake in the car
1. disconnect the parking brake wire of the dual from ur ebrake wire in your car.
2. take your 2 wire toggle switch and connect one wire to Ground(metal)
3. take the other wire and connect it to the parking brake wire of the dual screen.
if i remember correctly, the pattern for the dual screens is.
1. starting in the off position.
2. on for 2 secs
3. off for 2 secs.
4. then on .. the the video will show.
hope this helps
Oct 04, 2009 | Dual XDVD8181 Car Video Player
My pioneer indash avic d3 wont play dvd's you
this until has a safety feature installed that will not let you view video while in motion. it has a light green wire on the back that is supposed to be connected to the cars ebrake wire so that in order to view video you would have to have your ebrake ingaged. it also allows you to be able to type in address for the navigation. if this wire is not connect or not connected properly, you will get a messages that says drive can not view video will driving..
double check the connection....or you can just bypass it completely. i have attach a link on how you bypass this feature which will allow you to watch video and type in nav address while drivin
http://avic411.com/forum/viewtopic.php?f=11&t=7998
Aug 15, 2009 | Pioneer AVIC-D3 Car DVD Player
Cant play the dvd player
You need to solder the back pins on the unit. We can do it at www.turbotunes.com
-Steve
Apr 09, 2009 | Pioneer AVIC-N2 Car DVD Player
Bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Mar 24, 2009 | Pioneer AVH-P4900 Car Video Player
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
How do i bypass the emergency brake wire on a dual xdvd700
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Dec 01, 2007 | JVC KD-AVX33 Car Video Player
Jensen
is it the solid yellow wire if so that is the memory wire and it should be hooked up. if you are talking about the parking brake wire you either need to hook it up the the parking brake spring or bypass it
Nov 21, 2007 | Jensen VM9510 Car DVD Player
AVH-P4900 E-Brake ByPass?
my name is derrick and i found out how to bypass the e brake using a relay if you need help email me at [email protected] and no you don't need a switch.
Nov 15, 2007 | Pioneer AVH-P4900 Car Video Player
Jensen VM9510 Car DVD Player Logo
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
