Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
Two routers US robotics connected together
I have US robotics 5461 Wireless router and USR 9112 as ADSL router. The USR 9112 works fine alone but when I connect its ethernet output to WAN port of USR 5461 I cannot access internet any more neither with ethernet cable connecting USR 5461 to laptotp nor using it in wireless mode. I assigned 192.168.2.1 to USR 9112 and 192.168.2.3 to USR 5461 and let my laptop as dynamic IP assignment. Any suggestion on how should I configure those two routers to make them work toghether??
The general idea was to use the USR5461 as wireless router and the USR 9112 as ADSL modem.... Many thanks. Regards. Domenico
  • Anonymous Feb 03, 2009
    whether two routers connected to each other uses all the three OSI layers?
  • 556 Answers
It appears you may have confused the world because of your IP addressing choices. Do you know what a subnet mask is? It determines which machines share the same network with other machines. Routers by design are the connection between different subnets, Most routers default to 255.255.255.0 for the subnet mask which means both of your routers are in the same subnet as they are 192.168.2.? meaning you have two separate networks sharing the same same subnet address when they should be unique. Try making the wireless router 192.168.3.3 or 192.168.3.1. This puts devices in your wireless network on the 192.168.3 subnet and the devices in the ADSL subnet in the 192.168.2 subnet which includes the WAN half of the wireless router. I believe this will correct your network issues. In this case if hardcoded the gateway for the wireless router would be 192.168.2.1 also known as the the adsl modem
Posted on Dec 06, 2007
Owners manual
I cut the text from your problem: U.S. Robotics MAXg USR5461
and pasted it in to Google.
The first non-sponsored result was:
http://www.usr.com/support/product-template.asp?prod=5461
Sep 10, 2012 | U.S. Robotics MAXg USR5461 (738168036790)...
USR MOdel 5461 Ce numéro
Just reset it! At the back of the router is a small hole.With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
Jan 01, 2011 | U.S. Robotics USRobotics USR5461 Wireless...
I have a U.S. Robotics USRobotics USR5461 Wireless router
heres the online installation manual http://www.usr.com/support/5461/5461-ug/index.html
see configuration tab - You will not be prompted to login the first time you connect to the Web User Interface during the initial setup. During the Setup Wizard procedure, you will be prompted to create a user name and password to log on to the router. If you create a user name and password, you will need to use these whenever you want to log on to the Wireless MAXg Router. The user name and password are case-sensitive.
------------- so if you cannot remember the username and password - you will need to reset to fsactory condition and reset all the settings in the router for it to work with your ISP again
the reset button is on the back - RESET Button: To restore the factory default settings, use a paperclip to press in and hold the RESET button for five to ten seconds. If the RESET button is pressed for less than five seconds, the Wireless MAXg Router will reboot.
Apr 24, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
I cant menagment wit mu usrobotic i cant go insade him
get manual link above all explained with pictures.
Apr 08, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
I forgot my custom ip address of us robotics so now how i can connect to it
The default address for that make and model is: http://192.168.2.1
If you changed the default address, you can perform a factory restore to reset the router.
To restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
You will lose all of your personal settings if you restore the factory default settings.
Mar 20, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
How do i find my network key or create one for security?
Login to your router and check to see if wireless security is setup:
Use Internet Explorer and type 192.168.2.1 in the address bar.
Login using the password you created when you setup the router.
You can view the wireless security settings and retrieve the key.
If security is not setup you can enable it....directions here:
http://www.usr.com/support/5461/5461-ug/wireless.html
Mar 11, 2009 | U.S. Robotics MAXg USR5461 (738168036790)...
Mac address
Look here:
http://www.usr.com/support/doc-popup-template.asp?url=5461a/5461a-files/clonemac/clone-mac.htm&loc=unst
If not, here is the support page:
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 25, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Password problem
Look for the quick setup in the box, or try this http://www.usr.com/support/5461/5461-ui/setup_cable.htm
admin admin is what you're looking for.
Carl
Aug 26, 2008 | U.S. Robotics Computers & Internet
Laptop wifi cannot find usr model 5461
I use the windows wireless zero program which all I read is the best for wireless and aliminates conflicks
Dec 30, 2007 | U.S. Robotics USRobotics USR5461 Wireless...
Open Questions:
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
486 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
