Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Problem for Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Twirly thing under the vacuum has stopped spinning
By kinkbondage on Aug 18, 2009
Purpose for Pets Dirt Devil. Out of nowhere the twirly brush thing in the beater bar no longer turns. There is still suction, and when I push the second power button (on the head of the floor attachment) the motor or whatever it's called starts up and it sound fine, but no action. The cords aren't loose or anything. It has worked like a champ for almost a year. Can you help?
Best Solution
posted on Aug 18, 2009
Very Helpful)
JWOODS89
Rank: Wiz
Rating: 80%, 27 votes
there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" Thank you so much!! I did try to take the bottom off my vacuum earlier and could only find one screw so I didn't want to break it. Will try again! <3 " - kinkbondage
Popular Solutions for Dirt Devil Featherlite Bagless
Questions and Unsolved Problems for Dirt Devil Featherlite Bagless
Do you recommend Dirt Devil Featherlite Bagless Vacuum M085845Vacuum?
Answer
Answer
it just stopped working. it is only about 1 year old, the filter is new. stopped the other day... (More)
Answer
My roller is clogged with hair and is difficult to move. How do I remove it to clean away the hair?
Answer
I have a bag less featherlite dirt devil vacuum I bought n 2008. Whenever I vacuum dust goes... (More)
Answer
How do you wrap the cord around the vacuum cleaner without it keep falling off?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , CA
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
