Fisher and Paykel IWL12 Top Load Washer
Problem for Fisher and Paykel IWL12 Top Load Washer
Seems to be clogged and will not drain
By kingporgy1 on Aug 18, 2009
seems to be clogged and will not drain
a bath mat's bottom surrface completely crumbled into a sand like mixture
Comments:
Aug 18, 2009
- thanks again I will give that a shot and reach out to you if I have more questons I appreciate your prompt response
Aug 18, 2009
- Hi Again There are no side, front, nor rear panels to rome on this Fisher & Paykel GWL15 washing machine Any idea as how to access for the strainer Thank you
Best Solution
posted on Aug 18, 2009
Very Helpful)
woobie dog
Rank: Guru
Rating: 88%, 363 votes
Your strainer's likely plugged with the "sand". Locate your dtrainer, situated between the drum and pump, and connected to the drum with a rubber hose. Clean and reinstall it. Get all of the sand out, and remove any that you can see laying in the pump cavity, etc. Run an empty load to flush the machine. This may have to also be done a second time if there is a lot of residue.
--W/D--
Comments:
Aug 18, 2009
- Hello again!
Usually, top loaders are accessabe by removing the rear panel, where front loaders are usually accessed by removing the kick panel under the main front panel. The strainers are usually attached to the pump housing, and most have a screw-in lid woth an "O" ring gasket. They are very tight, and it may take some leverage to get it started off. I use channel locks to gain mechanical adventage over it the first time. I always give the "O" ring and threads a shot of silicone spray before reassembly, just in case I ever have to go back into it.
Best regards, --W/D-- Thanks for rating my solution!
Aug 18, 2009
- You may have to remove the top to access the side fasteners.
W/D
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thank you how do i get to the strainer please advise " - kingporgy1
Popular Solutions for Fisher and Paykel IWL12 Top
Questions and Unsolved Problems for Fisher and Paykel IWL12 Top
Do you recommend Fisher and Paykel IWL12 Top Load Washer?
Answer
Answer
I have a Fisher & Paykel IW812 Intuitive Eco. The problem started by randomly flashing... (More)
Answer
in spin cycle it bangs as it spins. i rearrange the clothes inside bt it still bangs. if i take... (More)
Answer
water take long to fill and rinse and make a noise during process
Answer
have water temperature set at hot. When water starts to fill, it is hot but changes to all cold
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , OH
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
