Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic viera my red tint is gone from my tv. only an orange tint. any advice? i need help.thanks,bigeazyatzeg
    Novelist:
  • 192 Answers
Does it happen with all inputs?
The most common problem I have found with this type of problem is a component cable coming loose from the television or cable or satelite box. If this is the case you can check by turning on the DVD and see if it has the same problem.
If only one input has this problem and the input devices work well with the other inputs, then, the problem would be in the main board.
Check the tint, is it centered? It should be.
With the color turned down is there a good black and white picture (Does the set have a good gray scale)?
These are the questions that my shop use to identify the source of the problem before we schedule a service call.
Posted on Dec 02, 2007
I am having picture problems with my n 64 connected to a Panasonic viera. The picture is black and white and very grainy if anyone can help I would be very grateful thanks
If there is no yellow socket (terminal) on the TV, as in most recent year's VIERAs:
Connect the Yellow male plug from your gaming device into the TV's GREEN female socket (terminal).
Press INPUT on the Panasonic TV remote and select the Video input. In some VIERA models, you need to press INPUT, go down and select the Comp. option and then press >right to select Video.
To get audio (sound), make sure to connect the Red and White plugs from the gaming device into the TV's Red and White sockets (terminals) that are labeled AUDIO.
Mar 26, 2016 | Panasonic Televison & Video
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
My panasonic viera has a red orange coloring. when i press the menu button, the coloring in the menu is normal. what is wrong and how do i fix it? thank you.
Check the blue and green plugs on the component cable. Make sure the are pushed in all the way on the back of tv and device (cable box, dvd player, etc.)
Aug 06, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera missing the red color spectrum?
Ours is doing the exact same thing! I came here hoping to find an answer. Did you figure your tv out?
Nov 26, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
GREEN TINT TO ALL DVD'S PLAYED
Your red component cable needs replaced or your red component input in either your DVD player or TV needs replaced.
Jun 13, 2009 | Panasonic SC-HT730 System
Making my HD tv look the best it can
If you have the halo 3 bonus disk use the THX optimiser on it, if not then the setting I use are:
Viewing Mode: Dynamic
Contrast: 60
Brightness: 50
Colour: 50
Sharpness: 50
Tint: Middle (need the lenses to set it properly)
Colour balance: Cool
Colour Management: On
P-NR: Off
I got both setup through HDMI atm.
Jan 06, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
I used your advice today about replacing the fuse Thank you!
Gonna need a little more info than that - - - I get nearly 3000 emails a day and I'm not sure what page we're on...
Bill
Jun 08, 2008 | Panasonic CT-36SX12 36" TV
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
