I have a toshiba 305 and get the error message the instructions at 0x760f6770 referenced memory at 0x760f6770. the required data was not placed into memory because of an i/o error status 0f 0xc000000e.
It is memory related issue.
First check in back side of laptop and refix RAM memory .
Also you have remove bugs in harddisk for that boot your laptop with recovery disk or bootable winxp disk then enter in recovery console mode then type in prompt "chkdsk /r" then press "y' then it fix error on harddisk.
For refix RAM you have open 1 small plate in back side of laptop it is for RAM module.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite L305D-S5904
I need to replace the fan assembly on TM 2480 and do not wish to make a mistake.(the fan assembly...
(More)
I need to replace the fan assembly on TM 2480 and do not wish to make a mistake.(the fan assembly does NOT have easy access.)
i have a 1510 but i cant see any bluetooth option on every window and option . is this model have...
(More)
i have a 1510 but i cant see any bluetooth option on every window and option . is this model have internal blootooth? where & how can i active it?
