Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
No water after new installation
We just installed a new dishwasher started it up and no water seemed to be going in? The water supply is on. We installed a braided hose for the water?
Can you help?
  • Anonymous Dec 05, 2007
    Had the same problem when we started ours for the first time. You will hear the dishwasher run and it is a feature that pumps out any water left in the dishwasher before it begins it cycle. Cost us $75 for a repair man to tell us that if we would have let it run for a few minutes we would have gotten the water supply
    Scholar:
  • 196 Answers
Start the unit and let it run for 30-60 seconds to allow the sensors to detect water. The unit should start. If not, Loosen the water line at the valve and check for water. If there is water. the next step is to unplug the water valve electrical connection and check for voltage across the terminals. If there is power, change the valve. No power, the circuit card is suspect.
Posted on Dec 29, 2007
SOURCE:
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
    Hi -
    I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
    Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
    ** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
    I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
    If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
    Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
    Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
    Regards, BElectric
    Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
    No water in washing/rinse cycle of dishwasher
    It sounds as if the warter inlet valve (solinoid) isn't working and might have to be replaced. If everything else opeates fine, (unit pumps and sprays water that you added to it, pumps out and drains OK, then it is very likely the inlet valve has failed.
    You can check for a blockage in the water inlet line, but unless you have a lot of sediment in your water or use a private well for your water supply, that would be a remote possibility, but worth taking a look at before buying replacement parts, etc.
    You can remove the water supply hose/line and check for proper water flow and see if there is anything blocking the water from getting into the dishwasher. Many uints have a filter screen installed in them, so check that to see if it is blocked. Otherwise, look at the inlet valve and see if it is working correctly and go from there in replacing it.
    One last thing, make sure the water supply line is actually providing water to the dishwasher, sometimes the water valves some installers use do get blocked, depending on how it was installed.
    Jul 28, 2009 | Crosley Dryers
    Dishwasher Not Getting Water
    The water inlet valve could be faulty or possible some obstruction in it.
    Aug 12, 2017 | Frigidaire Dishwashers
    Brand new dishwasher installed and water leaks out bottom of door
    If your dishwasher leaks, check these:
    Main tub seal
    Door gasket or seal
    Water-inlet valve
    Hoses
    Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
    Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
    • Lower rack
    • Spray arm
    • Spray arm support
    • Wash/drain impellers
    Then pry the seal out of its housing and replace it.
    Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
    Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
    The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
    Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
    Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
    No water is coming to dishwasher
    Check and see if you have 120 comming to the fill valve. if you do the start to loosen the hose you connected to make sure the valve actually opened when you turned the water back on
    Nov 25, 2008 | Maytag 24 in. MDB4651A Built-in Dishwasher
    Kitchenaid double-drawer dishwasher will not start
    i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
    Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
    No power to dishwasher
    depends on the sequence. many, but not all, dishwashers start with drain to get rid of the slops. if yours starts with fill, then no water supply will prevent progress.(you should be able to hear a low hum which is the valve energised) check also that the door is closing properly and latching. better to use cold water fill not hot
    May 09, 2007 | Frigidaire GPDB698SSBK Dishwasher
    Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
    71 people viewed this question
    Top Kenmore Dishwashers Experts
    Fred Sops
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
