Question about Tomtom GO 910 GPS Receiver
Installing battery in tom tom 910
Instructions
  • chuck0904 Aug 04, 2008
    I need to change the battery on a Tom Tom 910. How does the display lift out of the frame? I need more detail on the disassembly. Thank you
  • diannealexan Mar 29, 2009
    internal battery needs replacement how to open?
Remove the rubber strips from the bottom of TT there are two screws each side.
The top of the unit will then come off easily.
Then you will see a cast iron casing the battery is buried deep in it.
To access battery remove the circular shaped circuit with two screws.
Then remove five screws around the main circuit board.
Then you will see the battery.
Then remove a sliver strip which holds the battery in place and the eject mechanism for the TT arm.
Now is the hard part the battery is wedged in so I took a large screwdriver and forced it out.
I did crack the casing a little but it was easy to knock it gently back into place.
Important when you put the battery back in you will have to apply a little pressure, then do not forget to place the eject button into the same pin hole that the sliver strip sits in.
Oh and connect battery.
Good luck
Jack
Posted on Apr 26, 2009
Just proceed like Jack000 through unscrewing all parts to see the battery. But then remove two black holders at each short side of the instrument and take out the screen. The battery can now be very easily removed without the need for any special equipment and without any risk for distorting the casing.
JohnJW
Posted on Jun 17, 2009
    Scholar:
  • 143 Answers
If its in warranty return it.
if it is out of warranty & you really need to atempt it yourself you will need a set of torx screwdrivers.
T8 gets the cover off
T6 for inside
& the battery is deep inside you may need to peel off several security stickers & bend a few metal tabs to release the old one but as long as you put it back in reverse you should be alright.
Posted on Dec 15, 2007
  • 3 Answers
I have TomTom 910 in USA, (and I have one in the UK). Access to the battery is behind the front screen but the plug is under the circuit boards.
1) Remove 4 screws under ends of rubber strips on back. (All screws are Torx number 6)
2) Remove back cover. Front frame around screen comes off easier now.
3) Remove 2 screws in round top circuit board. Remove 4 screws from lower circuit board. These two boards may have a glue connection. Do not worry if it separates
4) Lay back circuit boards to unplug battery. Note flat ribbon cables are fragile. The 3 wire plug is the battery. Unplug wires to battery from receptacle on circuit board.
5) Remove front screen by pressing a screwdriver against the small metal tags that follow the edge of the screen. The tabs need to be pushed in slightly to allow you to lift the screen out. It may need some leverage, but be careful not to put the screwdriver to far behind the screen as there are a couple of thin cables for the connections.
6) To remove the hard drive you may need to unscrew the vertical black tags about 2 cm long. These simply come away and are grasping the business card size silver box IE the hard drive. The rubber end caps are pressed in, pry out with small screw driver.
7) Remove battery and replace. Note the two sided sticky tape around battery. When putting more tape on, be careful you do not put to much around the right hand end as it will connect with the thin cable when you put it all back together.
9) Reverse assembly. Mine works fine now, good luck. (and so does mine! BLP)
Footnotes: I did not have a Torx #6 screwdriver nor could I buy one locally. I found a #7 mini star bit works just fine. Source: Harbor Freight item # 93316, 6 piece Mini Star Bit Set - $3 PMVN - 9/19/2009
I am not advertising but Batteryship.com included with the battery #5 & #6 torx screwdrivers, a very small philips (star), a straight screwdriver and a plastic pry tool. Whatever I paid more than another place it was worth it.
When disassembling do not remove the battery clip. Just pop out the battery from the front (experienced having to reassemble that whole thing). Also having a set of tweezers to put the electrical connections back together helped a bunch.
Posted on Feb 09, 2011
    New Friend:
To remove the battery easily you need to pop the screen out.
This is done by pushing in three tabs on one long side where it clips into the casing.
Try removing the screen before you take the rest of it apart you may find it can all be done from there, I'd already taken it apart before I realised what needed to be done.
Posted on Apr 21, 2010
    New Friend:
I just did this successfully in 15 minutes. batteryship.com sells the battery, the requires torx drivers and a thing to help remove the screen all in one package for $20. And they ship overseas.
Posted on Oct 27, 2009
I just replaced my battery. I ended up with two little rubber grommets and have know idea where they go. Once I got rolling it went back together fairly easily and worked perfectly. The battery came with a "star" driver, but I had already bought a small set at Home Depot. I'll keep the set I got, but didn't need to have made the purchase.
Posted on Nov 17, 2008
  • 502 Answers
There are third party TomTom Repair Guide websites that show you how to replace / resolder components and replace the battery.
Posted on May 25, 2009
SOURCE:
SOURCE: not charging
Actually the link provided below is not valid , i went to the web site and searched for tomtom 910 and here is what came up: http://www.megacapacity.com/23922.html
Posted on Jun 25, 2008
SOURCE: how to reset tom tom 910
i can not see the reset switch help
Posted on Oct 31, 2008
  • 54 Answers
SOURCE: favorites button greyed out on tomtom 910
when you update the maps favorites are erased the favorites will also remain greyed out untill you have marked atleat one address or location as favorite
Posted on Dec 28, 2008
kenpodoc
SOURCE: Faulty battery on my Tom Tom Go 910
Go to this site and get the pdf with pictures on how to do it. Just be careful with the hard drive cable. Delicate tabs.
http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
Posted on Aug 02, 2009
SOURCE: tom tom
HI I HAD THE SAME PROBLEM, GREEN LIGhT ON BUT NOT SWITCHING ON.
I contacted tomtom and with in 2 weeks i have my original 910 back in full working order. AND I DIDN'T COST ME A PENNY.
My tomtom was an insurance replacement due to stupid little thieves, but i didn't have any form of a receipt. I contacted free and they went through the normal try resetting the device BUT HOLD DOWN THE RESET BUTTON FOR 30 SECONDS NOT THE 15 THEY STATE IN THEIR HELP SECTION. Done that and it DID SWITCH ON only for a about 1 min due to the battery not holding its charge. So they sent me all the packaging to return it to them, did ask that i put proof of purchase in but couldn't so just wrote a quick not saying insurance replacement but checked when i activated my device on my computer it was july 2006 so expected to a repair fee thinking it only had 1 years warranty but if you brought after Jan 2005 it has a 2 year warranty. Received it back today full working order and the battery replaced. Worth contacting TOMTOM number is on www.tomtom.com/368
Hope this helps.
if that doesnt work and u need to replace the battery... there is electronic cards one is two screw remove that and second one has four screw remve all and remove the sockets than you remove two more screws from under that after remove battery carefully this is little bit diffucult be carefull
please check out the disassmebly instructions in the below link...
regards iversh
A very helpful rating is appreciated for responding to your
query....
Posted on Aug 30, 2009
Can i get free map up dates for my tom tom go 910
You can get free shared updates from the users when you install the Tom Tom Home Software, but to update the map with the TomTom approved information, you will have to pay, unfortunately. So far, the people-uploaded maps have helped me immensely, though.
Sep 25, 2009 | Tomtom GO 910 GPS Receiver
We have bought a tom tom 910 its about threeyears old it worked at first but now it wont work at allthe green light wont come on all the time to
Try doing a device update while connected to tomtom home, if that doesnt work backup your device onto your commputer and try reinstalling the software and maps ect onto your device.
Aug 02, 2009 | Tomtom GO 910 GPS Receiver
Tom tom 910
Stip down your tom tom unit, google for instructions and there is a set with pictures, But if not,
1, take the front screen surround off first, be gentle and prise it of with a flat screw driver, then unsrew the chassis from the plastic cover (4 x torx screws under the rubber feet)
2, unscrew the motherboards (torx again) and unclip the cable for the battery, and remore the eject mechanisum for the unit.
3 you may hadve to unscrew the harddrive and front screen if memory serves me well, but not to hard to do at all and my skills are basic but backed up by curiosity :o).
Jul 03, 2009 | Tomtom GO 910
Blank screen but green light is on
I have had this on my 910, It turns out that the motherboard needs replacing and after looking on here its quite common.
Its quite esay to replace and perhaps worth changing the battery whilst your in there as well.
Google for instructions or flick through this site.
Apr 15, 2009 | Tomtom GO 910
Jan 31, 2009 | Tomtom GO 910 GPS Receiver
Tom Tom 910 software
I don't think the Tomtom 910 has a SD card slot. Check the model # of your GPS again.
Apr 01, 2008 | Tomtom GO 910 GPS Receiver
Problem with conection tomtom 910 to PC
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Feb 22, 2008 | Tomtom GO 910 GPS Receiver
TomTom go 510
COMMON PROBLEM SO FAR WITH THESE. IF STILL UNDER WARRENTY CALL TOM TOM THEY WILL REPLACE THE BATTERY UNDER WARRENTY
Feb 20, 2008 | Tomtom GO 910
Tomtom GO 910 GPS Receiver Logo
6,332 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
