LG KS20 Smartphone Logo
Posted on Aug 18, 2009
SMTP Problem sending emails on LG KS360 to vodamail SA
I am able to receive email, browse the web ets from my LG KS360, but cannot send when using vodamail.
Using the same vodamail account and sim card on my pc, i have no problem.
Using a telkom smtp server there is no problem on the KS360.
Using the smtp.vodamail.co.za with or without authentication does not work on the Ks360, but its fine when i move my sim card to the PC.
thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
411
Points
I have a problem of inserting a picture with HTML code in vodamail Pro 9.60, as i insert html code rather than picuture an icon is displaying with a box, how to trace this problem
2helpful
I can't send out emails. I'm receiving emails.
The problem seems to be in SMTP server configuration, SMTP server sends email. So, you have to check your SMTP configuration with your email provider.
May 06, 2011 • iPhone Apps
In Yahoo mail. Will not send email. Says "Processing your message". Never sends. I am receiving my emails as usual.
If you use any email client like outlook or other then make sure yahoo smtp server and smtp port are configured properly. If you use web based yahoo and receive this error then there is problem at yahoo server side . For that you need to contact yahoo customer support for fix this yahoo email server issue. Let me know if you need further assistance. Thanks for using FixYa.
Oct 13, 2010 • Yahoo Mail
Can receive but can't send email
I can receive but can't send mail using my POP mail client. Why? If you're able to receive but unable to send mail using your POP mail client (such as Outlook), please review the possible trouble areas below.
SMTP Server
In the fight against unsolicited commercial email (spam), some Internet service providers require their subscribers to send mail through the ISP's own SMTP servers. If you experience problems sending email, please contact your ISP to determine if it requires different SMTP server settings. You will need to use the ISP's SMTP server in place of Yahoo!'s SMTP server when configuring your POP mail client.
The following is a partial list of ISPs that require you to use their SMTP servers. If your ISP is among them, try replacing the Yahoo! SMTP server with the ISP server in your POP mail client settings, or consult the ISP's help files. (Learn more about configuring your client.) If your ISP does not appear in the list below, please contact your ISP directly for more information.
MSN smtp.email.msn.com NetZero smtp.netzero.net Verizon outgoing.verizon.net Earthlink/MindSpring Please visit its help pages AT&T Please visit its help pages Bell Sympatico Please visit its help pages SBC See below SBC Your SMTP settings will vary based on your account setup. Choose the SMTP setting that corresponds to the email address most like the one provided to you by your ISP.
[email protected] smtp.ameritech.yahoo.com [email protected] smtp.flash.yahoo.com [email protected] smtp.nvbell.yahoo.com [email protected] smtp.pacbell.yahoo.com [email protected] smtp.prodigy.yahoo.com [email protected] smtp.sbcglobal.yahoo.com [email protected] smtp.snet.yahoo.com [email protected] smtp.swbell.yahoo.com [email protected] smtp.wans.yahoo.com For more information about AT&T's SMTP requirements, please visit the AT&T help center or contact AT&T DSL support at 877-SBC-DSL5 (877-722-3755) or AT&T DIAL support at 866-SBC-DIAL (866-722-3425).
SMTP Port
If you have adjusted your SMTP server, and you're still experiencing a problem, you may need to use an alternate port. In an attempt to control spam, some Internet service providers now block port 25, which means you may need to use port 587 when sending email via Yahoo!'s SMTP server. Learn how to change ports.
Antivirus Protection
If you have Norton AntiVirus enabled on your computer, you may have to make configuration adjustments to use Outlook or Outlook Express. For more information, visit the Symantec web site.
Authentication
The Yahoo! SMTP server requires authentication. Learn more.
1helpful
I want to know what is the outgoing server for yfi. I am using the vodamail account. I can receive emails but can't send from the Yfi connection
Please try this below
Incoming server: pop3.vodamail.co.za
outgoing server: smtp.vodamail.co.za
or
smtp.vodacom.co.za
further lemme know...
Thanks for joinning fixya
I am not able to send emails today. I use Outlook Express and although I have not changed any settings and everything has worked in the past - today I can receive but not send?
Being able to send but cannot receive means that you cannot connect to your SMTP (simple mail transfer protocol) server. SMTP is used by Outlook in sending out emails.
Your outgoing mailserver is defined in your settings so to check if you can connect to its SMTP, you need to open a command prompt and type:
telnet you-mailserver-here 25
It should give you a new command prompt with a welcoming SMTP above. If it gave your a request connection failed, then most probably the smtp service is down.
Does your email has a Webmail interface? IF yes, try to send out your emails thru webmail temporarily until SMTP service port 25 is up. It is also advised that you inform your email administrator or service provider about this.
For further clarifications, please dont hesitate to ask me.
Sep 07, 2009 • Yahoo Mail
Using thunderbird mail program on lap top. can receive e-mail, but can not send e-mail on any public wi-fi connection. error message says can not connect to mail server on port 25.
most isp blocks port 25 for sending out mail that's the reason you cant send out mail, ask you wifi(ISP) smtp settings and you need to set it on your smtp server so you can send out mail using thier smtp as outgoing server.
OR ask you email provider about your webmail address and manually send out mail using the web interface of your email hosting.
btw have you try to change you smtp port to 587 sometimes it work.
2answers
Can,t send emails
what email client are you using ?
if your using outlook for your email client. you must configure first...
if its web-based like yahoo... update your browser.. use firefox or netscape or anything...
2answers
Emails
Most of the email service providers, dont allow you to send email(they give this as a paid service). You can configure your SMTP settings on your email account properties with the SMTP server details given to you by your email service provider in order to send emails, Contact your email service provider for the SMTP server details.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
