Question about HP Pavilion dv1000 Notebook
Lap top hp notebook series
Press start button attemps to start then display an error : disc read error then says press alt ctrl del reboot and same happens again help
    Scholar:
  • 112 Answers
One of 3 things have gone bad, either the hard drive and/or motherboard and/or the drive ribbon cable. First try removing the hard drive and reinstall the drive and try booting the laptop, if it still does the same thing, then it is time to send to the repair center. BPCS
Posted on Dec 06, 2007
SOURCE:
I tried alt control del. the screen is froze as well as the mouse
The sequence is CTRL ALT DEL. Press the Power Down/OFF button for several seconds, the notebook t should turn itself off. Reboot.
Dec 16, 2013 | HP 2133 Notebook
Disc read error press ctrl+alt+del to restart. does not work
Either the disc you are trying to read has an error or your optical drive has failed.
Mar 08, 2012 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Just bought a used dell alienware m15 laptop. I7 intel core I turned it on once... and it booted extremely slow!!!! Than it would not open any apps... or reall do anything besides move the cursor around...
I would do a complete operating system reinstall.
The M15x uses a program called Dell Datasafe Local Backup for factory restores. You can access this program from launching the application from within Windows (it is on the Start Menu), or by using the F8 Windows Boot Options menu. Press F8 after the iniital POST screen (Alien Face), but before you see the Windows logo on the screen. There should be an option to repair Windows, which will launch you into a recovery mode that allows you to restore the system. This option is available even if you have uninstalled the Dell DataSafe Local Backup app from Windows (I did, as its constant polling causes stutterin in Blu-Ray playback). Good luck!
Mar 19, 2011 | Computers & Internet
How to reboot my computer
Either press the "Reset Button" on machine. hold down the CTRL-ALT-DEL all at once. Remove/Turn Off Power. Or if at desktop from the "START" button and click on the Padlock at bottom and choose it from there. OR press CTRL-ALT-DEL and task manager will pop up... then choose reboot from the Shutdown Tab.
Jan 30, 2010 | HP Pavilion a1520n PC Desktop
MY LAPTOP WONT GO TO THE START MENU
you need to click ctrl+alt+del hit cancel and it will work :)
Jan 17, 2010 | Toshiba Satellite M55-S135 Notebook
Got power, frozen machine
okay what you need to do is if you have the system restore cd use that , it will reformat your lap top even if it cant reboot just put in the cd when you start up the computer and it will restore everything you may lose alot of things but atleast your lap top will work after , if not then Reply to me at Jonk3y at Aol.com and i will gladly help you with your problem
Sep 23, 2009 | HP Compaq Presario CQ50-103NR Notebook PC
On starting hp pavilion m7680y. I get: AOL error:
Open the Windows Task Manager (in WinXP) by pressing and holding down CTRL-ALT-DEL. In the Applications tab, highlight each program and click the End Task button. Once the Applications tab is empty, close the Windows Task Manager. Then, launch AOL again. (If you’re using an earlier OS, such as Windows 98, press CTRL-ALT-DEL to open the Close Program window, and close every program except Explorer and Systray.)
Jul 10, 2009 | Computers & Internet
NTLDR is missing
it means press ctrl+alt+delet at the same time and then you can turn of things from there
Jun 23, 2009 | HP Compaq Evo n400c Notebook
HP DV 5000
Are you sure you didn't make an error while recovering. The c-a-del doesn't always work with reboot.
Jul 11, 2008 | HP Pavilion dv4000 Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
