Question about Citizen CBM 1000 thermal Printer
Cbm 1000 thermal printer
The blade stops halfway though paper and quits, error message after.
  • 32 Answers
Replace cutter assy. Part # Acc-230kit or send in for service.
Agson - 856-751-9048
Posted on Feb 12, 2008
  • 14 Answers
Ideally blow out with compressed air to clear paper dust. Then spray with silicone lubricant in between operating the cutter, push it manually if needed. Worked on mine, if it goes halfway then the motor part works it is just dry or bunged up.
Posted on Feb 10, 2012
CANON PC428 COPIER PAPER WON'T FEED.
Check the paper feed roller, it's posible to be worn. If it's worn out, you need to change it.
In know a trick than can help you temporarily, clean the roller with windscreen cleaning solution and a rag. (i make same trick with my copiers, and it's working)
All the best !
Dec 06, 2017 | Canon Office Equipment & Supplies
REAR WIPER ON 2007 CHEV UPLANDER QUIT WORKING. IS STUCK HALFWAY UP REAR WINDOW.
Your motor is more then likely locked up. Replace the wiper motor. First check the relays.
Oct 13, 2014 | 2007 Chevrolet Uplander
How to convert serial cbm 1000 printer to parallel
I have an old cable lying around it has 1 serial plug a parallel plug and some others hanging on both ends. I can plug anything into anything in seconds. Obtain such a plug it you can. http://www.ebay.com/itm/Parallel-Printer-Cables-Parallel-to-Serial-Cable-5ft-/281215620527 Hey only $1
Nov 29, 2013 | Citizen CBM 1000 thermal Printer
Where does the ink cart. go for a cbm 1000?
Do you actually have an ink cartridge for a citizen cbm 1000 ? Because as far as I know they are all thermal printers that do not use ink cartridges they use heat sensitive paper. Which is why they are used in retail as they don't have to change ink cartridges as well as paper and are much more reliable.
Apr 30, 2011 | Citizen CBM-1000 Thermal Printer
I have a citizen 1000 printer that when it prints leaves off the item and total sales from the paper receipt. How can I reformate the cmb 1000 to show item and total sales?
You'll have to provide a lot more information. What POS software are you using? Are there printer settings within that application? Are you using the correct print driver? What operating system are you using? Did the printout work OK before, or has this started from Day One?
Oct 31, 2010 | Citizen CBM-1000 Thermal Printer
Low voltage Error, Citizen CBM 1000 II thermal printer.
check fuse 2 as this would cause the 3 short 1 long flash code. Even if its not blown at least you can trace that part of the crcuit for other blown devices
Aug 02, 2010 | Citizen CBM 1000 thermal Printer
I have citizen reciept printer idp3551.It prints but there is nothing on the page
check the direction of your thermal paper, (i know it seems silly) also check that your element is clean and in working order,
Mar 08, 2010 | Citizen CBM-1000 II Receipt Printer PC...
Citizen CBM 1000 thermal Printer Logo
339 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
