Question about GE Profile??¢ Built-In Compactor - 15" - White
G.e. profile compactor gcg1540f0ss
Compactor compacts,then at end of cycle it will not shut off and continues to run and vibrate. you then must then turn dial from start to run to get it to shut off
  • Anonymous Jan 18, 2008
    My compactors just vibrates, sounds like a jack hammer,
    Any solutions?
    Charlie@clyne.com
  • antberr Feb 10, 2008
    I am having the same issue.. and the door to the compactor will not open more than a few inches.. i can see the motor is not completey raised.. anyone have a solution??
The nut on the ram drive fell off for me and the chain fell off and then broke the grear drive. At 72$ each for the two ruined gears I don't know if I should try to repair it or get a new one.
ERRR
Posted on Apr 24, 2008
My ge profile 15" compactor stopped compacting. I
The "wheel" has a cracked center that you can not see unless you take the whole gear off.( I am assuming the "wheel" is off the motor and should be driving the chain that goes to the side gears ) There is a tension washer looking thing that holds it on and you can force it off with a flat screwdriver. Once off, I'm sure you'll see the center of the gear( hex shaped) is not engaging the hex gear shaft for being broken somewhere. An appliance repair store should have that part for less than $50. Sure beats the $85 the service people start with for just a service call.
Dec 11, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Kitchenaid compactor KUCS03FTSS makes banging sound at end of cycle
I bought a Kitchen Aid trash compactor the end of Sept/2008. By July/2010 I have spent $528 on having it fixed! It only cost $623 new so I called Whirlpool customer satisfaction line where after waiting 15 minutes was told that "With all due respsect mam, Whirlpool owes you nothing" Then " as a courtesy" they offered me 50% off an $80 part that I still need to pay $60 in labor to install! So,that would be an additional $100 on an appliance that has been trouble from the get go...I have had numerous compactors before this brand and have never had any trouble...Do NOT buy anything made by Whirlpool as they have apparently, a NO customer satisfaction policy.
May 17, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
When cycles completes will not shut off
the momentary switch is bad.
In easy terms; the white push button down low that the foot petal triggers is bad. You can try pushing it in an letting it snap back.
This worked for about a week, but in the end I had to buy the part and replace it. $63 online,
Cheaper than a $75 service call
Feb 20, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor ram stuck partially down & door open 2 inches. How do I get the ram to go back up & get the door closed?
We just had this same problem. Your problem is most likely abroken plastic gear found at underneeath the bottom of the compactor. Pull out the compactor and turn it upside down. Remove the bottom panel and that is where we found the broken gear. We were able to retract the ram and open the drawer by manually turning the drive chain using an ajustable wrench. Clockwise is compact, counter clockwise is retract.
Feb 03, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor continues to run when cycle is complete
the little white swiitch that the foot petal pushes is bad.
it may help if you push it in and let it snap back.
That was a temporay fix for me, but I ended up having to replace the part.
$63 online
took about 30 minutes to repair
Jan 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
GCG1700 willnot compact.When activated it just
There is a motor jam. The mechanism needs to be cleared, perhaps a bone or any other hard material is jamming the mechanism. Do a visual inspection and look for foreign objects (Perhaps a fork?) or something unusual.
Jan 06, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Ram will not reverse at end of cycle
ive been a repairman for 17 years but havent had to fix a lot of these because ther not out there,but have done some.it drives on a worm gear and i suspect that theres some wear there and its jumping the gear and thats where your getting the poping noise.their not the funest but you,ll have to take apart and opperate and watch/inspect.hope that helps God bless
Jan 03, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
My KitchenAid trash compactor model KUCP021RBL1: cycle does't end
Most likely the motorwindings have been overheated after staying to long time in down position and trying to get up.
If there is a Emerson motor in your compactor than you will not find anything wrong most likely it is the winding of the motor, we have had this two times, changed the motor and the problem is solved.
Kind regards,
Paul
Netherlands
Dec 30, 2008 | KitchenAid P Series Trash Compactor -...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile compactor
Here is an assembly drawing of your compactor.. Please note item # 102 ( direction switch) ..That may be affecting the perfomance of your motor or your motor may have a dead spot on the windings.. Here is a link to a website for parts that coincide with this drawing.. There isn't an awful lot to a compactor in terms of hardware so good luck.. Hope this helps..
Here's the link for parts... http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
Aug 19, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
GE Profile??¢ Built-In Compactor - 15" - White Logo
214 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
