Question about Frigidaire Refrigerators
TOP FREEZER REFRIDGERATOR MODEL FPWE19RWO
My Frigidaire Eite model #FPWE19RWO, serial #LA21100828 date of manufacture 03-92 of WCI Canada does not defrost. It was my sister'sand she gave it to me from her rental house. It works really good right after I defrost it with a hair dryer by taking the interior back of freezer off but once it works for a while it frosts up and the cooling is poor. The coils seem to fost well when I start it - I beieve there is a problem with the defrosting. I don't have an owner's manual so I don't know if there is a defrost adjuster somewhere in the fridge or freezer or if it is just broken.
Any help you can give I ould certainly appreciate it.
Thank you, Ken Taylor
[email protected]
SOURCE:
22yooper
  • 828 Answers
SOURCE: Frigidaire Frost=Proof Is Icing
There is a defrost timer located in the refrigerator compartment in the area of the controls. It will be covered by a plastic panel but there will be a hole in the plastic through which you can access the clutch head screw to advance it into defrost. Turn the screw clockwise very SLOWLY until you hear one audible click. this will put the system into the defrost mode. Defrost should happen in 18-22 minutes . after the 18-22 minutes the system should automatically return to cooling. If it does not restart after 25 minutes turn the screw a little farther to the second click. If you had to turn the screw the second time to restart the cooling replace the timer.
If the system restarts automatically but does not defrost your problem is an open defrost heater or defrost thermostat. These are located behind the back wall inside the freezer section.
Posted on Jul 07, 2008
  • 87 Answers
SOURCE: Water dripping from top of fridge (coil housing?) under freezer.
It could well just need defrosting. It does sound as though the coil in the freezer section is frozen. If you try defrosting it and the problem disappears then you have at least found a temporary solution. If it does rectify it I would closely monitor the cabinet for a couple of weeks to check for a reoccurrence. If it does reoccur then I would suggest contacting a fridge guy so that he can check the defrost circuit. The reason we normally suggest to defrost is incase a door was left ajar and the coil froze up because of this. I hope this is of some help and you seem to be on the right track.
Posted on Sep 11, 2007
  • 5 Answers
SOURCE: Samsung RS2545SH coils freezing
Hey how's it going? I may have the info you need, but first I need you to go through a check list to see if there is a simple fix.
Check to see if there are any obstructions in the freezer drain (freezer drain located inside freezer compartment behind back panel lower right hand corner of the freezer coils) if there are obstructions or debris remove and clean with a mild dish washing detergent and water, check to see that water can drain freely. see if this helps.when the coils freeze is the ice flaky or is it frozen solid ice? if the ice is flaky it could mean that either the refridges/freezer door are left open to long "check your door gaskets or seals by closing the on a dollar bill if it pulls out easily with little to know resistance your door gaskets may need to be replaced. After you defrost the freezer coils did you notice if there was water in the condensor pan, if so good sign. (condensor pan: is the pan that collects the water that drips through the drain hole of the freezer compartment caused by the heating of the coil by the coil heater: water that enters the pan collects and is reused by the condensor fan by blowing warm air partly into the water and through the condensor coils causing them to cool.)if you still need to test your bi-metal therostat or your glass heater/ice pipe heater, you will need a multimeter and knowledge on the use of it.(IF YOU 'RE NOT NOT COMFORTABLE AROUND ELECTRONICS AND ELECTRICITY PLEASE CONTACT A QUALIFIED REPAIR SERVICE AND REMEMBER TO UNPLUG APPLIANCE BEFORE ATTEMPTING ANY REPAIRS) for more info on how to test please reply,Good Luck, be safe..
Posted on Aug 24, 2008
SOURCE: FREEZER ICED OVER, LOWER COMPARTMENT NOT COOLING
Well, if the service person said the defroster is not the problem, there must be a good reason. But, I would go with a faulty defrosting system. Most likely suspects are the defrost timer and the defrost heating element.
Posted on May 05, 2009
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
What year was this model made?
Your unit (B3BV-036K-BB) is a Westinghouse / Nordyne Unit.
Vertical Flow only, 36,000 BTU, 208/230 volts.
You cannot tell the manufacture date from a model number, only from the serial number. Try contacting manufacture with the serial number...
(nordyne.com)
Sep 13, 2014 | Frigidaire Heating & Cooling
Wb73805358
Hello friend, thank you for allowing me to assist you!
I see you are looking for the date of manufacture for your Frigidaire freezer. According to your serial number I show your freezer was produced in 2007. I hope this information is helpful. -Matt
Aug 16, 2014 | Frigidaire Freezers
How do I get parts for a frigidaire refridgerator
Good Afternoon jgl1222 - Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor).
May 11, 2013 | Frigidaire FRT18P5A Top Freezer...
I am thinking about buying a used ge monogram range. Model number ZDP48L4GH3SS. I am trying to find the stats for it, but I am having no luck. Would especially like to know how old it is, what it weighs,...
All in the links below.
GE Appliances Model and Serial Number Locator
www.geappliances.com/ge/find-model-serial-number/
Find Your Model & Serial Numbers. Select your product type. Refrigerators & Freezers. Compact and Wine & Beverage Refrigerators · Bottom-Freezer Refrigerators · Chest Freezers · Icemakers · Side-by-Side Refrigerators · Top-Freezer Refrigerators · Upright Freezers. Cooking Products. Advantium Ovens · Cooktops ... Missing: zdp48l4gh3ss
How to Determine the Age or Manufacture Date of a GE Appliance
products.geappliances.com/appliance/gea-support-search-content?contentId=16195 How to Determine the Age or Manufacture Date of a GE Appliance. The manufacturing month and year is coded into the serial number (not the model number) of the appliance. Our serial numbers begin with two ... for further assistance. For information on old RCA appliances, see RCA Appliance Age or Manufacture Date. Missing: zdp48l4gh3ss
Discontinued Models - GE Appliances
www.geappliances.ca/en/products/discontinued-models Discontinued Models · Explore our GE Collections. Our Company. About us. Our Story · Appliance Donation Center · Press Room. Websites. GE Appliances Worldwide · Business to Business · Corporate Website · Careers · Monogram Design Centre ... Missing: zdp48l4gh3ss
Parts for GE ZDP48L4GH3SS Range - AppliancePartsPros.com
www.appliancepartspros.com > GE > Range Original, high quality parts for GE ZDP48L4GH3SS Range in stock and ready to ship today. 365 days to return any part.
Parts including Gas burners
http://www.appliancepartspros.com/parts-for-ge-zdp48l4gh3ss.html
These are posts about that Range
https://cse.google.com/cse?cx=partner-pub-9933858514302629:4836214790&q=ZDP48L4GH3SS&oq=ZDP48L4GH3SS&gs_l=partner-generic.3...146736.146736.0.147883.1.1.0.0.0.0.115.115.0j1.1.0.gsnos%2Cn%3D13...0.42j1764j2..1ac.1.25.partner-generic..1.0.0.BUEnm5lSMk4#gsc.tab=0&gsc.q=ZDP48L4GH3SS&gsc.page=1
Weight and Specs will be the same at 538 lbs.
ZDP48N6DWSS GE Monogram 48 Professional Range with 6 Burners and Griddle...
Jan 24, 2018 | GE Monogram ZDP48L4GHSS Dual Fuel...
WCI refrigerator model # MTRT21GNGW4 power is on but compressor not working / cooling
ck the relay / listen for clicking noise / it may be trying to start . also ck the fan under and inside . the must be working when comprssor is . and last clean the coil it dirty . mm
Sep 01, 2010 | Frigidaire FRT15B3A Top Freezer...
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Refrigeraotr is out but freezer still works
doesnt make adiff how you loaded freezer, shouldnt affect fan operation anyway. if you have a meter you can check for proper voltage(110v) to fan wires and if you have power youll need to replace fan, easy enough to do just a few screws and about $50.. part number 5304445861.
Oct 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerators Logo
119 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
