Question about Car Audio & Video
Phoenix digital 1.5 farad capacitor installation
I lost my installation instructions for this capacitor. I know I need to "charge" it before I install it and I have to use a bulb or something to do it. But how is it done, and once that is done how should it be connected to the amplifier.
  • Adam25 Dec 03, 2007
    Thank you very much!
  • 709 Answers
First off Charging the capacitor can put you holding a high power voltage source. This can be very dangerous. It is enough to kill you. I suggest for safety go ahead and mount the capacitor in its location. The easy way to charge a capacitor is using a 12 volt Battery Charger. Hook the charger up to the capacitor just like it is a battery. + to + and - to - ... Charge the capacitor until the charger meter falls to near zero amps or indictates full charge. No need to use a light bulb or anything. The Charger comes with it own limiting circuitry. I will be posting the wiring instruction shortly.
Posted on Dec 02, 2007
  • Greg Stokes
    Greg Stokes Dec 02, 2007
    The Red wire coming from the fuse and battery should come to the Capacitor Plus. Then another red wire from capacitor plus to your Amp 12 volt +. Tie the minus to body ground, more than likely uner the same screw or bolt where you amps black wire is tied.
Blower motor doesn't start with capacitor installed!
you need a meter that will measure uf (micro farads) it should read within about 10% of the rating 12.5uf otherwise you could charge it with an insulation tester (megger) and short the terminals with an INSULATED screwdriver to see if it discharges.
Dec 21, 2009 | Goodman CKL24AR24 Air Conditioner
Hey i had 2 car amps +for 4 speakers(140W maxi) and a sub 12inch
1 cap, either .5, 1 or 1.5 farad will be fine. they make 5 10 and 20 farad that cost way more than u need to spend for 400 watts RMS. i like the rockford fosgates, you can get a low cost Tsunami, just make sure you follow the charging instructions.
Oct 20, 2009 | Car Audio & Video
35 Farad hybrid power capacitor not charging like instructed in manual, tryed charging the cap throgh the supplyed resistor "2watt/10ohm" between power cable and cap.But nothing happens seems like it dosnt...
Yes you certainly wire the 12v+ wire directly to the positive post of the stiffening Capacitor, however if you have a one of those test light probes to check for current on a car? They are really cheap but what i do is clamp the one end on to the battery and than touch the probe to the + teriminal of your capacitor, when the light goes out your cap is fully charged. Now if the light does not go all the way out or stays on you have a bad capacitor, and might i ask why the hell are you driving to need a 35 Farad Capacitor anyway?? Damn.. We do show and competition cars here and sometimes use them. I like the BatCap way better, it's a Battery and a Capacitor all in one. Way strong like bull..... good luck... Mark
Aug 14, 2009 | Boss Audio CAP10 10 Farad Digital...
I NEED TO INSTALL CAR STEREO AND WIRING KITS
Rather than me typing forever and maybe missing something-go to CARAUDIOHELP.COM and they can give you the entire breakdown on how to install it and why,good luck
May 20, 2009 | Car Audio & Video
Boss 3.5s capacitor?
something in the order of 120 ohms. If you use a 1/4 watt size it will get extremely hot.
May 15, 2009 | Boss AUDIO CAP2C 2 FARAD CAPACITOR DIGITAL...
I have a Rockford Fosgate 1 Farad capacitor, power cap how do i wire it in to my car. i know one side is what about the other side is it or -
hi there installing a capacitor is at your own risk as they charge up and hold a lot of power if hooked up wrong can give you the shock of your life and blow your sterio and computers to bits i learnt my lesson any way remember to take off positve before installing here is a diagram how to install it,,,, ok the positive goes to the battery and the amp on one side and the other to ground .....take a look at this easy to use diagram i found for you hope all goes well http://www.caraudiohelp.com/images/car_audio_capacitor_installation.gif
Jun 30, 2008 | Rockford Fosgate Car Audio & Video
Car Audio & Video Logo
1,154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
