Question about Soltek SL-86SPE2 Motherboard
My computer won't start?!
I have a Soltek SL-86SPE-L Motherboard which has a red LED on the board itself that lights up when the power supply is switched on but the computer wont start when I hit the power button.
I have tried swapping out the power supply and power switch and these both work OK. All components (AGP graphics card, sound card, modem, DVD drive, memory and hard drive) all work on my other(new) motherboard.
So I have decided that its a motherboard problem, this was expensively confirmed by a PC repair shop ($400 inc. new mobo).
My real problem is why the mobo's red LED still lights up but the computer won't? And to whom do I turn to in order to fix my motherboard?
All of the capacitors look OK to me (not domed or worse).
My only lead is a slightly louder static crack from my PC speakers on the last shutdown.
I gather that something got fried but I don't know where to look and is it even worth looking at all??
More of a technical problem I know but you probably know more than I!
Any advice would be much appreciated.
  • 1 more comment
  • joyos7 Mar 22, 2008
    Yeah, my computer has the same problem described by the other guy.Instead of a red led light its green on the mobo.So yeah Im guessing towards a fried cpu.
  • gwverhage Sep 25, 2008
    hello
    i had the same problem
    i removed all the hardware but not the grafic and thememory. when I start the computer the red led is stil burning and there is also a beepsinal
    is this means that the motherboard is gone
    greatings willem
  • Anonymous Nov 24, 2008
    I have the same problem as described by others. Could the problem be related to the CMOS??? Which symptoms will be seen, if this is the real trouble?
    Greetings Henrik Malmqvist
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well if ytou were already using ur PC then may be the last time ur PC was improperly shutdown. this can cause many mail functions.
now 1st thing to do is remove all the hardware and just leave the Processor, Memory & Graphic card if Any. then start the PC if its power on then Motherboard is OK if wont then Dis Assemble all The parts and then assemble again and try as mention above if it still wont work then may b ur chipset of the board friedd out that you cant visually say its fried.
Posted on Jan 06, 2008
SOURCE:
Soltek SL 86SPE L board
http://www.hardocp.com/article.html?art=NDkyLCwsaGVudGh1c2lhc3Q=
That's the best i could find.
Jul 10, 2009 | Soltek SL-86SPE2 Motherboard
Motherboad Drivers for SL-86SPE-4(LG)
Try here: http://www.intel.com/support/chipsets/sb/CS-009241.htm
Maybe here: http://www.intel.com/network/connectivity/products/desktop_adapters.htm?cid=cim:ggl|lad_dsktp_adap|kAC2|s
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=816
If it will help you could alway add a PCI nic card to the system. (Supported by Vista).
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3350631&CatId=200
Oct 27, 2008 | Soltek SL-86SPE2 Motherboard
Soltek SL-86SPE-L CPU upgrade issues
Maximum you may go upto 2.4 GHZ. [p4]. Not dula core etc.
Best Regards
Rafique
Feb 17, 2008 | Soltek SL-86SPE2 Motherboard
This took ages to find... and EVEN LONGER to download, it felt like I was on pre-pre-pre-pre-56kbps era.
Anyway, without further ado:
Soltek SL-86SPE/SL-86SPE-L BIOS AM1.5L. Included:
  • Flashing App
  • How to
  • ROM file
86SPE-L15.zip
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Soltek SL-86SPE-L motherboard prolem with audio controller and lan card
yes buy extranal x fi sb sound card and nice linksys pci network card disable onbord crap ok
Jan 19, 2008 | Soltek SL-86SPE2 Motherboard
Soltek SL-86SPE-L and 512MB 400MHz memory cards
If I could find your manual, I would bet that your memory should be CL2 or a max of CL2.5 which is the core voltage of the memory.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-21
A lot of places do not show the CAS or CL voltage, rather they make you look for it. Thats just wrong.
Jan 16, 2008 | Soltek SL-86SPE2 Motherboard
865PE-775G and hang in loading windows
its most probably a problem with the windows installation itself, u can either reinstall the windows or there's a better solution but its kinda hard: you have to keep clicking the F8 button when u start your pc, a list will appear, so choose "safe mode" and not any other option, after the windows start you will find a screen asking u if u want to contine in safe mode or if u want to restore system to a previous point, if u click "no" u'll start the system restoration program from which u choose the last time ur windows was working properly and click "restore system to this point" and after that the system will start the restoration procedure and after the restart u'll see if it worked or not, if it didn't then installing a new windows is the only option since there isn't any connection between the motherboard or hardware with the operationg system except if the motherboard doesn't support this operating system.
Jan 03, 2008 | Soltek SL-865PE-775G Motherboard
Soltek SL-865PRO2-FGR Motherboard Problem:
Generally an FF code means either a dead board or a dead motherboard... =/
Although you may not have changed anything, motherboards can die for the strangest of reasons, and in my personal experience, this is what this means.
Nov 07, 2007 | Soltek SL-865PRO2-FGR Motherboard
Red Light on Board
it is better to use the old power supply because it is compatible to your mother board
Feb 11, 2007 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Soltek SL-86SPE2 Motherboard Logo
188 people viewed this question
Top Soltek Computers & Internet Experts
Ekse
Paul Bade
Steven Wander
Steven Wander
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
