Question about Sony PlayStation Portable (PSP) Console
PSP unresponsive When a game is loaded the direction buttons will not respond and the highlight indicator just roams all over the screen, it does not respond to anything. I was told to replace the D Pad but I don't see that it would solve the problem. Plz help
  • 709 Answers
Hi Flying back,
I think your PSP may have had a confrontation with moisture. It sounds like the D-pad has one of the circuit pads shorte together full time. If one of the direction pads is always on, it will ignore the rest or add to them for a diagonal move. You need to open up your PSP and Look closely at the circuit pads for a form of short circuit across from one side to the other. you can scratch the short away if you find one. This should help. Good luck.
Posted on Dec 02, 2007
SOURCE:
When i press the home button oy psp, i cant use the directional bons to click yes so that i may quit the game i'm playing. and sometimes the "o" button seems to be pressed while i'm...
The problem, as you describe, is exactly that! One of your buttons is stuck down in the pressed position. If you press Home and the screen comes up asking you if you want to quit and a button is already pressed down, you will not be able to press X to confirm yes or no.
You didn't specify which PSP you have, 1001, 2001, or 3001, but the following website sells the part you need to fix this issue. They also perform repairs if you're not comfortable doing it yourself. It's a pretty cheap and straightforward part to replace:
PSP 1001:
http://store.richspsxparts.com/pspbucibo.html
PSP 2001:
http://store.richspsxparts.com/pspslpricibo.html
PSP 3001:
http://store.richspsxparts.com/pspslpspsric.html
Jun 16, 2011 | Sony PlayStation Portable (PSP) Console
My playstation 2 won't play any disks period.How can I fix this?
To start the auto diagnosis feature
Press the standby/RESET button on the front of your PlayStation®2 computer entertainment system to turn on the system. Make sure the indicator light turns green.
The Main Menu screen will appear.
NOTE: It might take some time for the main menu screen to appear.
Using the directional buttons, highlight [Browser] and press the (X) button.
Highlight [System] and press the (X) button.
Highlight [Diagnosis] and press the (X) button.
Highlight "On" and press the (X) button.
Insert a disc.
Auto diagnosis will start automatically.
The system will make adjustments that might allow previously unplayable discs to be played.
To start the disc after auto diagnosis is complete (for 30000-50000 series):
Press the (O) button twice to return to the browser screen.
Press the (X) button to play the disc.
if still not work then apply this
Just take some rubbing alcohol and cotton buds. Gently clean the lens. If this won't help - the laser needs to be replaced. Don't worry, they are cheap now.
Aug 18, 2010 | Sony PlayStation 2 (PS2) Console
VERY SLOW LOADING
please go to this link and follow the instructions to perform a hard reset on your PSP.
  • Step 2 Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
  • Step 3 Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
  • Read more: How to Reset a Sony PSP | eHow.com http://www.ehow.com/how_4854080_reset-sony-psp.html#ixzz0qo5PPO00
    Jun 14, 2010 | Sony PlayStation Portable (PSP) Console
    Psp is frozen with blank screen. Nothing happens at all. No buttons work and we've recharged
    It's BRICKED then.
    You'll need to buy Magic MS + Pandora Battery.... from somewhere online! Won't cost you much!
    Nov 09, 2009 | Sony PlayStation Portable (PSP) Console
    My psp joystick is broken. it is stuck down. when i play games, the person is always crouching or going down. and the highlighted section in the menu is always going down. I've looked for solutions on how...
    The PSP of my son just so happen to have same problem as yours. Aside from the joystick, the 4 directional button (Up, Down, Left and Right) also controls the directions (hmmm... as the name implies). I was able to correct this by replacing the worn out FLEX PCB at the back of the directional button found just underneath the PSP casing. The trace of the Down Button on the PCB is already shorted to the ground which causes the signal to be always active even it is not pressed.
    Oct 26, 2009 | Sony PlayStation Portable (PSP) Console
    PSP wont quit game..
    buy new motherboard sounds like you press the keys too hard and the board cant read it cuzz you broke the recievers
    Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
    The screen is black,
    Sometimes the PSP's will freeze for one reason or another. In most cases the psp will turn off within a minute and then restart itself. If not disconnect any power supply and remove the battery for a moment to manually reset it. Hopefully you saved recently.
    Feb 21, 2009 | Namco...
    Quitting game
    Let me get this right, if you power off the PSP and turn it on everything is in slow-motion and dragging? or It does this after you try to quit?
    Jan 24, 2007 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    178 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Ekse
    shevantha perera
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
