Question about Canon LS-100TS Calculator
I want two decimal points to show
Now only rounded number shows
  • 2 more comments
  • OTISJUNKIE Mar 14, 2008
    TRIED RESETTING FROM BUSINESS TO TAX-NO HELP
  • tus33 Jul 09, 2008
    Does this calculator support more than 1 decimal place result?
  • rtangue Sep 18, 2008
    This is so frustrating. I had the calculator in my bag, pulled it out one day & all of a sudden it now only shows 1 decimal place on computations causing me to get inaccurate answers on tests and such. I've spent numerous hours trying to find the solution on how to change it back and no luck. Not even Canon's website can provide any assistance.
  • happywindy Nov 13, 2008
    for + _ * / calculation, decimal digits missing.
    for example 13+0.3 = 13
I called Canon customer support. There is a tiny reset button on the lower back area of the calculator. Simply stick a small object in there to reset the calculator and you should be as good as new! Worked for me!
Posted on Sep 18, 2008
The reset button doesn't work for me either. But I discovered when I don't hit the "=" button, whatever decimal place is shown.
Eg. "1.252 x 1.2 + " I got 1.5024 it displayed the entire decimal.
Posted on Sep 19, 2008
  1. 100 and 200
Posted on Jul 28, 2008
5 Suggested Answers
SOURCE:
  • 8081 Answers
SOURCE: How do I get my Casio calculator to show only 2
Use the FIX format with two decimal digits
[MODE][1:Fix] 2 displays only two decimal digits.
Hope it helps.
Posted on Sep 25, 2009
t0pc4t
  • 132 Answers
SOURCE: MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Posted on Sep 08, 2009
  • 8081 Answers
SOURCE: Rounding off in Casio FC 200V
Press [SETUP] select FIX then press [EXE]. Enter the number of decimal digits you want (3 or 4). Press [ESC] then press [EXE]
Hope it helps.
Posted on Oct 05, 2009
  • 8081 Answers
SOURCE: all of my answers show up rounded to the nearest
  1. Press [MODE].
  2. Highlight Normal, it is not highlighted already, and press [ENTER].
  3. Use DownArrow to move cursor to the second line.
  4. If you want to keep all possible decimals digits highlight float and press [ENTER], then press [2nd][MODE] (QUIT) to exit configuration screen.
  5. f you want a limited number of decimal digits (2,3, 4 or 5), highlight the corresponding number on 2nd line an press [ENTER], then [2nd][QUIT] to exit configuration screen.
Posted on Mar 02, 2010
Can you help my son on his rounding numbers
Yes, you can post any question here. Ignore any grumpy unhelpful replies. Best to post in this Forum
http://www.fixya.com/troubleshoot/browse/homework
Alternatively have a read of these sites
http://www.factmonster.com/math/numbers/rounding.html
https://www.mathsisfun.com/rounding-numbers.html
Feb 28, 2017 | Miscellaneous
How do I stop calculator from rounding up?
Hi Carol,
There are switches at the top just under the screen called the "Rounding Switch" and the "Decimal Point Selector Switch".
With the rounding switch you can select rounding up or down, but you may also want to use the second switch to show more digits after the decimal. Put it in the "F" position to show all decimal places. When it is in the 0, 1, 2 positions, it strips off and round the numbers.
Here is the link to the manual as well, look at the section detailing the "Decimal Point Selector Switch".
(You will need an Adobe Acrobat Reader to look at the manual.)
Hope this will help you. http://downloads.canon.com/cpr/software/calculator/P23-DHV-(USA-HWB).pdf
Nov 15, 2014 | Canon P23-DHV Calculator
Write down all numbers which can be rounded off to 30
There's an infinite number of such numbers. If you're rounding to the nearest integer then any number from 29.5 to 30.49999... will round to 30. If you're rounding to the nearest ten then any number from 25 to 34.9999.... will round to 30.
Jul 30, 2013 | Office Equipment & Supplies
I am a new tenant in a building with a round Jackson dishwasher. I'm trying to follow the instructions. I can see two strainers, one round, and the other cylindrical. I've looked at the manual
You have neglected to include the model number which you must have if you have the manual. Jackson produced a number of models. That said, here is a site that may help you because it shows where parts go in a schematic:
Wash Rinse Assembly
Contact Jackson WWS
Nov 18, 2017 | Jackson Dishwashers
How do I stop my ti 34 ii calculator from automatically rounding numbers in scientific notation?
First, bear in mind that the calculator is going to round numbers eventually, as it can only show a finite number of digits.
You have some control over where and how this rounding takes place. Press [mode], down-arrow, down-arrow, then right-arrow to the choice of decimals desired. Press [enter] to select it.
Feb 24, 2012 | Texas Instruments Office Equipment &...
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
VB 6.0 ROUNDING A NUMBER
Use the Math.Round() function. It takes two arguments, the first is your number or a variable holding your number and the second is the number of decimal places. This will only round to fractions of a whole number though and you need to round to the nearest 10. So divide your number by 10 before you round to shift the decimal place once to the left and multiply by 10 again afterwards to shift it back again.
answer = Math.Round(32.1 / 10, 0) * 10
Apr 02, 2009 | Microsoft Visual Basic 6.0 for PC
Canon LS-100TS Calculator Logo
565 people viewed this question
Clive
Clive
old marine
old marine
Ekse
