Question about GE WBSE3120B Top Load Washer
Motor will not start in slow agitate
When the machine goes into slow agitate mode motor clicks on and off rapidly. motor is fine in all other modes (fast agitate, spin) I cycled through the field service mode. no error codes appeared.
    Champion:
  • 249 Answers
I rewound electric motors in the past, in your case i don't know if its a armature motor it would have brushs. if it was if its without brushs, it would have two septrate windings one for spin, one for wash. the wash windings could be 'faulty',answer! try other motor! if you get one. let me know which motor it is Ire,Close. bye for now
Posted on Dec 02, 2007
SOURCE:
GE washer agitation starts normal the progressively slows and then stops agitation. All other modes work fine. Model # unknown. Motor or transmission? Thanx people!!!
Model # located on the back of the control box of top load, just inside of door on front load. Other Op modes ok, problem points to agitator support shaft or the belt drive of the agitator.
Nov 17, 2015 | GE Washing Machines
User manual
Maybe posting the make and model of your unspecified washing machine, could look for a manual, if available
May 19, 2015 | Washing Machines
Enter service mode, GE GTWN5650FWS washing machine. won't spin or agitate...just makes clicking noise. drain pump works. timer counts down.can I check the transmission operation by putting mac
NOT SURE WHAT UR MACHINE WILL DO IN SERVICE MODE BUT DOUBT IT CHECKS TRANNY? THE LIKELY CULPRIT IN UR CASE MAY BE A DEFECTIVE DOOR SWITCH? OR WORN MOTOR COUPLER ( BETWEEN TRANNY AND MOTOR) DOUBT ITS UR TRANNY?
Sep 26, 2014 | Washing Machines
The washer starts in agitation mode. Will not do anything but agitate. Is it Water Level switch that needs to be replaced?
Washers start in fill mode as it requires the level of water set to start the agitator mode.. If your machine goes immediately to agitate then I would think that the agitator control module is failed and needs replacement. have an appliance electrician check it out.
Aug 17, 2013 | GE WDSR2080D Top Load Washer
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Washer goes half way through wash and starts clicking. Motor will go into overload. When turned to manual spinn will click but spin slow. Switching to another cycle will sometimes start it working. In...
Barings probably over heating and expanding due to either dampness, lack of lube, bent broken or misaligned coupling. Is a warranty issue either way unless it was dropped during transit or used exessively on uneven surface. If its out of warranty you might be better of with a new one, trade in if possible.
Oct 31, 2009 | GE WBSE2090A Top Load Washer
Kenmore washer aggiates slower than when new. is
Usually, there are two agitator modes. A Normal ("Fast") mode, and a delicates ("Slow") mode. Put washer in 'delicates' cycle and see if the agitator slows down even further. If it stays at same speed as in perma press or 'normal' mode, then there is an open in the circuit betwixt the controller dial and the agitator control.
Feb 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
GE WBSE3120B Top Load Washer Logo
121 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
