Question about Kenmore Elite 45986 Front Load Washer
Washer tub bangs
Seems like the tub is never balanced like it use to be. When it was new I never heard a banging when the tub spins. Now it does it all the time and take a while to balence itself. What can be done about this?
  • 1,294 Answers
Click on "troubleshooting" above and type "banging" after clicking "find solution", i have a couple of postings there. You could also read others.
Posted on Dec 02, 2007
  • prem mathew Dec 02, 2007
    Type "banging" in Knowledgebase and search.........its simple.
Washer bangs loudly in middle of spin cycle
Make sure the back spring is still on the back of the tub. That tends to come off sometimes. Check all the other springs while you're down there too. You can balance the unit if you tilt the back side of the washer and then set it back down. it has auto leveling feet. What's happening is once the water is all drained out, the unit will enter the final spin cycle and spin very fast putting the unit off balance so the tub bounces around.
Good luck, let me know if this helped.
Aug 10, 2009 | Kenmore 23012 Top Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Washer works fine till it gets to the spin cycle, makes very loud bang bang bang like it's going to blow up, did find two brass pins under the balance plates in a small cup that it droped down into, lined...
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Unstable tub
There are springs inside the unit that stablize the tub during spin. If the springs are not attached correctly the tub will be off balance. Sometimes the Balance Ring loses it's fluid due to a crack or leak and the washer will spin off balance. THis requires a service tech to dissemble the machine.
Nov 27, 2008 | Kenmore 24032\24036 Top Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
220 people viewed this question
Sal De
 Brian Main
Brian Main
