Look at local tip for similar size with similar power output.
Take info off motor and look up companies to match --- manufacturer- electrical- online search
Only label is an after market sticker from General international......went to electric motor specialist store and they could not help with matching to a new motor. No markings on the motor at all
their are two models of this unit this site move thru the photos then click to enlarge the two plates with the m otor infohttps://www.biddergy.com/Listing/Details...
SOURCE: Noisy headstock on 15 inch variable speed lathe
Usually not. Is lathe leveled, and base secured, check for soft feet. This can set up vibration and load bearings.If motor is belt drive check belt condition, pulley alignment, belt tension.
SOURCE: looking for info/ manual for a wool lathe
look under cwl12d clarke wood lathe manual. this has all the instructions that are almost the same as the nwl37-2 i have a nwl37-2 and this manual shows what should be there.
SOURCE: I have a 12' craftman wood lathe Model #113.228162
There are a couple in the Grizzly catalog on page 139. Here's a link to it:
http://www.grizzly.com/catalog/2011/Main/139
Testimonial: "Thank you very much for the help!"
SOURCE: Where ca I get parts
Sorry mastercraft tools are made by Canadian Tire. You can not get parts for the item They will not sell parts or supply them. We get a lot of requests for parts and have called Canadian Tire and they will not tell us where to get parts. You can try to call them at (1-866-746-7287) or here is the mastercraft tool direct line. 314-429-3333
SOURCE: looking for an owner's manual
To get a owners manual call 1-800-469-4663 or go to www.sears.com with model number tool type and serial number if possible.They should be able to fix you up. Good luck and thank you.
